Well , I was on a sleep, after that my phone alarmed I woke up, then i
go and stop it . It ask me to snooze or stop , i press stop. Then it
mention that switch on my phone or not ? I press On . Then the screen
goes blank.
Maybe between my sleep ,there is phonecall ringing and till it used all
the batteries power? But I charged it for hour , and try press the
switch on button , it don't switch on. Whats the problem? How do i
solve it ?
A problem might have occurred in your phone, like for example,overheated maybe and melted the leads (silvery thing) joining the circuits or the connection between components or between the battery and other related parts. But I think there's just a minor damage at all. You might find part like it was burnt a very small fire.
I mean if you'll open your phone u might find burnt part,cause i think a shortage of electricity from battery occurred and caused short circuiting.
I'm not sure with this for it might worsen the damage.But I think what you have to do is open your phone if you can and find any anomalies you can suspect on and check also the leads attach the silvery dots...know it? some of it might have fallen and loose contact with the circuit. If you found some of it is missing, solder lead on the missing area. Using a soldering Iron.
well, the battery is the problem........it can charge but only a small amount of electricity.
Which is not enough to run your phone,even turning your phone on...it can't! You need a new battery for it, that's the only way to keep your phone working again.....tnx 4 asking. A rate from you will be much appreciated......
Try to remove the sim and your external memory before turning on your phone.. or short your battery.. find a paper clip and strip both end of it and touch both sides of the battery pin together.. then put back your battery and connect your charger then wait for 5 to ten minutes then turn on you phone..
Alarm clock
Open the alarm clock tab.
To set an alarm, select Options > Set alarm. When an
alarm is active, is displayed.
To switch off the alarm, select Stop, or to stop the alarm
for 5 minutes, select Snooze. If the alarm time is reached
while the device is switched off, the device switches itself
on and starts sounding the alarm tone. If you select
Stop, the device asks whether you want to activate the
device for calls. Select No to switch off the device or Yes
to make and receive calls. Do not select Yes when wireless
phone use may cause interference or danger.
To change the alarm time, select Options > Reset
alarm.
To remove the alarm, select Options > Remove alarm.
Good luck please rate 4 thumbs up and please leave a testimonial.
Chao Ci bai , No one helping , fixya was a lie.
@curseseal
There was no burn I think, as if it was a damage, what should i do ?
@elite_tech
I tried before coming to this post.
@Curseseal
No , I charge it like 1 hour , still I can't switch on , I can see the charging there.
I found no smell of the burn , If it was because of the leads that the circuit can't go through , but why I can see the Battery Charging on the phone ? And I look through it , I found no fallen loose contact with the circuit.
