Please specify your Nokia Mobile phone model Correctly.Nokia CE 0434 is battery model...You can try 1234 or 0000 for Nokia Phones,these are default Codes.If these code will not work in your Nokia Phone,Visit the site Simpleunlocking.com/nokia-dct-master-code-service/rs16wp10/ get master reset code for Nokia DCT phones and reset it from security lock.
You phone fails to recognize,the a look at this causes,might 1 of the problem is listed below.
(solutions are already indicated).
* your simcard might be corroded and need to be clean using a pencil eraser. * simcard socket lock might be losen and need to bend a little bit downward to reach the contact of the simcard. * simcard reader or terminal pins is dislocated and not properly align,need to fix in proportion or re-aligning. * simcard reader or terminal and its pin is corroded and need to be clean using any rust solution and a cotton.
If the above method does not work,simcard IC might be damage and need a parts replacement,by this time,you need to bring it to the service center to fix this problem.
you call to the simcard customer care and ask the pukcode number.you have to say the simcard registration number and then customer will give the puk code number.you enter to the cell phone.next enter 00000 or 0000 and repeat the numer to unlock security code..............
sir in nokia 2690 phone.in the inbox message right click and mark the messages u want to copy.and then copy the message to the simcard [not in the memorycard will not accepted pc also not accepted] u copy the message in simcard
hello,if it doesn't accept the sim card ten it is simlocked to another or probably the phone needed to be unlocked by your service provider.after it has been unlocked it will then work as normal as you wish.all that will be required of you is just your phone IMEI NUMBER and your mobile phone will be fully fixed to allow it accept simcard. please kindly rate this solution if it'shelpful,
Samsung D500
Switch phone on without sim and enter :-
#*7337#
if it does not work then you need a direct unlock in a shop
Samsung A300
*2767*637#
Model: Samsung A400
*2767*637#
Model: Samsung A800
*2767*637#
Model: Samsung E500
*2767*688#
In newer phones:
#*7337#
Model: Samsung E700
*2767*688#
In newer phones:
#*7337#
Model: Samsung E715
Turn off the phone. Put a non-accepted Simcard and turn it on. Type
*#9998*3323#. Press Exit. Choose menu #7. After phone reboots type
*0141# and hit the Call button. Turn off and insert another Simcard.
Turn on. The code is 00000000.
In newer phones:
#*7337#
Model: Samsung M100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play
Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE#
(Code is the last 8 digits of the NCK/SPCK)
Model: Samsung P400
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung S100
*2767*7822573738#
Model: Samsung S105
Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Model: Samsung S300
*2767*7822573738#
Model: Samsung S307
In newer phones:
#*7337#
Model: Samsung S500
*2767*3855#
In newer phones:
*2767*927#
Model: Samsung SGH600
*2767*3855#
*2767*2878#
Model: Samsung SGH2100
*2767*3855#
*2767*2878#
Model: Samsung V200
*2767*7822573738#
Model: Samsung X100
In newer phones:
#*7337#
Model: Samsung X600
In newer phones:
#*7337#
Model: Samsung Universal
TEMPORARY UNLOCK:
Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
try removing the simcard from the iphone by inserting the end of a paperclip into the small hole at the top of the i-phone, this will push out the simcard. Then clean the simcard and re-insert it into the phone, the issue should now be resolved. if it persists then it could be because you have a faulty simcard in which case take your i-phone to your nearest apple/o2 store and they should give you a replacement.
