There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps, www.PuterCare.com
If it starts to load the operating system and then the display goes black then chances are that the dispay/video drivers are corrupt.
Boot the machine into safe mode by restarting the computer and repeatedly press the F8 key as it starts. This should bring up a sub menu with safe mode at the top. Use the cursor keys to highlight safe mode and press enter. You will see white boot information scroll up the screen, be patient and wait for it to load up. Click on your account and you will see a message about system restore. You don't want to use system restore so click on yes to work in safe mode.
Right click on My Computer/Computer and click on manage from the list. Then select Device Manager.
Look in the list for display adapters and click on the + or > next to to expand the list. Right click on the display adapter and select uninstall.
Restart the computer and it should load up the operating system and reinstall the drivers for the display.
This sounds like a driver may have been updated, changed or has become corrupt, either after a bad update or virus/malware attack. Reboot the computer in safe mode with networking…when the computer reboots, open the control panel > device manager (in XP the device manager is in the system folder) > scroll to the display adapter. Right click on the adapter and roll-back the driver. Click yes and apply if necessary. Reboot the computer, it should reboot and display with no issue. It may ask (if you are automatically connected to the internet) if it can search windows update for a fresh driver….since you know what to do in case of a failed update, click yes and get a fresh driver. I would then do a complete virus and anti-malware scan to make sure the system is clean.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
If
the monitor screen remains blank (no startup screens or onscreen
display messages), the monitor must be connected to another computer
using a different cable to determine if the monitor is bad. Skip to the
Step to connect the monitor to another computer.
If the monitor is capable of displaying boot screens but is unable to
display Windows, use the following steps to set the computer to a
compatible resolution:
NOTE:
Find
the native display resolution for your monitor in the User Manual or in
the product specifications for the monitor model. If you are unable to
find the native display resolution for your monitor model, temporarily
use 1024x768 for troubleshooting purposes.
Turn on the computer and press the
F8
key repeatedly when the first startup screen appears.
If you are using Windows Vista, select
Enable low resolution video (640 x 480)
, press
Enter
, and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document,
Changing Display Settings, Background Image, and Screen Saver in Windows Vista
If you are using Windows XP, select
Enable VGA Mode
, press
Enter
, and wait until Windows opens. Continue using these steps to set display resolution.
If you are using Windows 98 or ME, select
Safe Mode
and perform the following steps to enter into a standard VGA mode:
Once Windows opens to the desktop in Safe Mode, click
Start
, and
Run
In the Open field type
msconfig
and press
Enter
The MS Configuration Utility window appears.
Click the
Advanced
button, and select
VGA 640 x 480 x 16
if it is available.
Click
OK
and restart the computer.
After Windows opens, click
Start
, and then click
Run
msconfig
and press
Enter
Click the
Advanced
button, and remove the checkmark next to
VGA 640 x 480 x 16
Click
OK
. Do NOT restart the computer.
After Windows opens, right-click on an open area of the desktop and select
Properties
(Windows XP, 98/Me) or
Personalize
(Windows Vista).
In Windows Vista, Scroll down and click
Display Properties
In Windows XP, 98, or Me, click the
Settings
tab.
In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to
Highest (32 bit)
In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to
Highest (32 bit)
In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to
True Color
Click
Apply
after you have made your adjustment.
The screen should blank out temporarily and come back.
If you are satisfied with the new display settings, click
Yes
on the Monitor Settings windows. If you are not satisfied or if the
screen just goes black, wait: Windows sets the screen back to the way
it was before. Try another setting until you find a display
configuration that is compatible with the monitor and meets your needs.
NOTE:
If
the native resolution is not available, download and install updated
video driver software for your computer. Updating the video driver
software can add more resolutions (graphics modes).
Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using
a different cable, connect the monitor to another computer that has
video. Turn on the monitor and the newly connected computer. What
happens?
If
the monitor works, the video hardware on the original computer is
likely to be the source of the problems. You can try connecting the
original computer to another monitor that works to update its video
drivers.
If the monitor remains blank, repair or replace the monitor.
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
may be u have problem with the display driver or u have a corrupted windows xp try to run the windows in "ENABLE VGA MODE" if it works fine then just reset the display settings else u have to try to repair / reinstall winxp
mai me ur response @ [email protected]
