SOURCE: protect mode
Press reset button (small circular button need something with a point) to the left of the 1 channel
SOURCE: Protect mode Kenwood KDC MP438U in dash reciever
Anytime there is a short circuit or your battery down low enough you will recieve this signal. If you press the little "reset button" using a small pin or screwdriver your unit should reboot without the "PROTECT" signal. If seeing this "PROTECT" sign is a result of jumping your car, this will fix it. If the signal persists, then there is still a short circuit and you need to check your connection with the battery. Most likely it is touching the chasis or some othere metal.
SOURCE: Kenwood KDC-MP732 CD Player in protect mode how do
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
