This is really mic problem .so try to clean the mic connector.if still not ok.change the mic.....and still the problem persist you need to make jumper.If you can do this reffer this image
the fault is probably coming from the board and might need replacement so as to enable the mic work properly. you can take it to a repairer to fix or change the board. on the other hand, it could be that the new mic was also faulty. the best thing to do is to take both your phone and the mic to a qualified repairer and see if he helps. hope this helped you? please rate
Clean the area around the mic and the opening of the mic. Probable some dust has gone inside the hole and blocked the mic.
If it does not solve the problem then you have to take the set to a technician.
Everything is possible at least in India mic change cover change don't know about the place you live in but the mic on a 6300 is similar to the one used in 5200 if you can lay ur hands on an old junk 5200 the mic can be replaced................ besides mics are available with any mobile technician
