Does your battery have a large spark when you connect or disconnect it? A small spark may appear. A large spark would be a large drain.
There should be a wire from the starter or a junction block that goes to the plug on the alternator. It is a voltage sensing wire. It is also a fusible link. If the wire is not melted away (thats how they work as a fuse) it may be corroded inside the white (or black) plastic connector.
Remove the plug from the alternator and check the larger wire on it for 12 volts.
The other end of the wire will go to either the starter or a junction block on the firewall or near the battery.
Look for these
Don't just look at them, give a little tug to see if they pull out of the bu-tt connector
And you can go to Autozone.com and they have free wire diagrams in the repair section.
