Hey in one of the things you solved you said that on that board if any of those barrel things are bulging at the top to replace them. Well a) what are their technical names, b) how do i remove them and c) where can i buy replacements? Any answers soon would be great before I go ripping those things out and breaking it.
They are called capacitors.You have to unsolder the bad ones,and solder the new ones back in.I bought mine off Ebay.Radio Shack has some,but they didn't have the ones I needed,and they are more expensive.Here is the link to the ones that I bought.You will have to look at the ones that are bad in your TV to find out the size you need.You should try to get it as close as you can to the original one.You can get one with a higher value on both specs,but not lower.For example,if there is a 10V 1000UF 8MM in diameter,and a 16V 1000 UF 10MM in diameter,you can replace them both with 16V 1000UF in diameter,and it will work perfect.You can also use different heights as well,as long as there is enough room.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
http://cgi.ebay.com/Motherboard-Caps-Capacitor-10mm-1000uf-16v-UltraLow-ESR_W0QQitemZ180143183301QQihZ008QQcategoryZ1244QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
