I have a 1998 dodge 4x4 1500.i have no interior lights at all and my power mirrors dont work.i just installed an aftermarket radio. it happened after the install.i checked all wiring and fuses.what is iud fuse and cwhere is it located.do i need to hook up my radio different.i need help.
The fuse for the interior lights has a yellow plastic holder
covering it. Full the holder all the way out, fuse and all, with a needle nose pliers.
Replace the fuse. Disconnect the power to the radio you put in before you do this. Replace with new fuse. Check lights. If light work, plug in radio. If fuse blows, radio connection is bad (grounded hot wire). Fix wiring, replace fuse, and try again.
You could also have messed up the multi-function switch
(turn signal switch). EVERYTHING go's through this piece of crapo switch, and it costs a fortune to replace. Do the wiggle test on the switch, wiggle it while trying the things that do not work, front to back of truck, NOT up and down like your turning the switch on, the opposite way, front to back of truck. If things flassh off & on that stopped working, yopu found the problem. DONT pusy too hard, push gently on end of stalk, there is a lot of leverage there!
I have a 1998 Dodge Ram 1500. My Dome, 2 reading lights, radio stopped working, does anyone know if there is something that ties all these together? I had put something in the glove box and pushed it up against the glove box light ( which didnt work before, so didnt know where it was). After that all the lights and the radio stopped working, the lighted mirrors are out also, but every other light works just fine. The lights on the stock radio work, but no power to the radio itself. If anyone has any info please email me at [email protected] Thanks
