In build , does that mean its built in to the display bezel>?
came that way new.
this pC is relic, CQ40 is over 10 years old.
most this are are useless now. worth like $20 or less.
are you failing to say this is CQ40-317tu? clearly
that PC came with VISTA and nothing else ,ever.
so that tells me you put W7 on it with out HP support.
they do not have W7 for this PC< period.
so when you loaded w7, you then seen that cam is dead.
and you are connected to the web, and the windows 7 plug and play can not find the driver for said relic, camera chip
ever think that w7 does not support chip,. due to the maker of it does not exist now or never ever made a W7 driver ever,for it?
you used a MICROSOFT DISK to do this, so now its not working
due to not using HP disks, then wonder why it dont work.
well you did that, you are now on your own STEAM.
no support . from HP nor MS, if PNP fails !!!
if there is a cure, we do this, we use PCI scanner
to learn the true name of maker and chip using that tool.
then with that fact we go to there web page and look for a Windows 7 driver or that exact cam chip. if there is none
then go to the store and buy a new camera what has W7 support.
you did that when you LIFT HP support.
You will find other things bad tool.
but if all you do is email, it works.
the HP software is a bundled package of apps and drivers.
that work as a team.
microsoft does not do that.
here is what you lost
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq40-300-notebook-pc-series/3781140/model/3870909
here is the PCI scanner free
seen here, and see the database to convert the codes to real names. scan it get the code ,look it up and if no longer in business
there is NO DRIVER. if you try to find drivers that do not exist
you will get A VIRUS, I PROMISE THAT, a 2017 horror of life....
http://pcdied.com/pci-101.html
SOURCE: hp compaq cq 40 108 tu laptop can i get audio video drive
can i get solution to install win xp on compaq cq 40-108
SOURCE: WEB CAM DRIVER FOR CQ 40 -108 TU COMPAQ LAPTOP
please help me to find webcam driver for my laptop CQ-40 115AU
SOURCE: compaq cq40 108 tu
Try the suggestions in this webcam article.
Use SplitCam to see if the program is working or not, this program is compatible with most webcams.
After that you probably need to check the webcam settings in the other programs you want to use it in.
Jules
SOURCE: UPGRADING INBUILT WEBCAM
You cant upgrade the inbuilt webcam.for that you can buy a external camera and connect it through usb
SOURCE: unable to find webcam driver for compaq presario cq 40
Here is the webcam drivers for that modelftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
Here is the page that I found them on and others that you may need
http://saysprasad.wordpress.com/2008/12/08/compaq-presario-cq40-108tu-drivers-for-windows-xp/
