When I switch the amp on it makes a loud buzzing sound that comes from within the amp itself and also comes though the speakers. It gradually fades away over a couple of minutes. What could be causing this? I have checked all my connections and everything seems fine.
Hi I have had the same problem with my nad c370 a few times over the last eight years which was repaired under waranty the first two times, also on a second c370 I bought to bridge and use as a backup because Ive found the c370 so unreliable, It is the caps in the protection circuit. I was quoted £175 to have repaired through audio t. though I got it done for £60 in a local tv repair shop.
You can't post conmments that contain an email address.
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
usually this would indicate a dry joint inside or some other temp related intermittent fault, component problem. Take it to a tech and tell them what happens
The buzzing is coming from the transformer. It is almost expected of an amplifier of this size, that the transformer (a large one) will excite the resonance of the casework and make some noise.
I would suggest that the fuse in the amplifier has blown. This is usually caused by a bad amplifier component (duh!).
The unusual part of your problem is that sound is being passed. When a component dies, signal stops as the continuity is broken.
Which could also suggest the power supply. Transistors work like relays, you turn on the control signal and the transistor opens or closes. It isa possible that this control voltage is not being passed.
Hi arda5 Did you try swapping speaker connections left for right on the back of the amp to isolate the problem. If the fault stays with the speaker, then that is where your problem is. Try this and get back to me here with the results.
