Cars & Trucks Logo
Posted on Sep 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Serpentine belt diagram for a 5.9 diesel with air and 9 pulleys
2004 dodge 3500 dual 5.9 diesel
  • Anonymous Feb 28, 2009
    the diagram for a dodge ram 3500 serpentine belt
Anonymous
Level 2:
  • Expert 133 Answers
  • Posted on Jan 22, 2009
Anonymous
Expert
Level 2:
Answers
133
Questions
0
Helped
123196
Points
376
5.9L DIESEL
serpentine belt diagram for a 5.9 diesel with air  - 196759.jpg The 5.9L diesel engine accessory drive system (with a/c) consists of :
  1. Generator Pulley (1)
  2. Water Pump Pulley (2)
  3. Idler Pulley (3)
  4. Power Steering Pump Pulley (4)
  5. Radiator Fan Pulley (5)
  6. Crankshaft Pulley (6)
  7. Automatic Tensioner (7)
  8. A/C Compressor Pump Pulley (8)
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to or for correct engine belt routing. The correct belt with correct length must be used.
1. Position drive belt over all pulleys except water pump pulley. 2. Attach a 1/2 inch ratchet to tensioner.
The 5.9L diesel engine accessory drive system (without a/c) consists of :
  3. Idler Pulley (3)
3. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
Changing serpentine belt on 2004 dodge ram 1500
Should be a diagram on hood.or at radiator .
2helpful
Routing serpentine belt 2006 dodge diesel 4x4
going clockwise starting on the passenger side of truck
1 over the alternator pulley
2 under the water pump pulley
3 over the idler pulley
4 over the power steering pulley
5 over radiator fan pulley
6 over crankshaft pulley
7 automatic tensioner
8 over a/c if equiped
2004 dodge ram 3500 turbo diesel/ 6 pulleys/serpentine belt diagram
sorry nothing listed under either chrysler or dodge in my europeon alldata books
I need the belt diagram for a 2004 3500 dodge cummins diesel
If no belt routing diagram on the hood or the radiator core support bracket, it's grooved part of the belt on grooved pulleys, slick pulleys on the slick side of the belt and 3/4 around the crankshaft pulley. Sounds strange but if you follow this rule of thumb, you can install any belt, Good luck, Gary
11helpful
I need the belt diagram for a 2005 dodge 3500 diesel 4X4
Check this diagrams (click for zoom)...
Fig. Accessory serpentine belt routing-2004-05 5.9L Diesel engines with A/C
Fig. Accessory serpentine belt routing-2004-05 5.9L Diesel engines without A/C
Hope helps (remember rated this).
2helpful
Serpentine belt replacement for a 2004 Dodge 3500 Ram Turbo Diesel with Air Conditioning!
check the hood or the frame rail around the engine bay. there should be a diagram.
4helpful
3answers
Can i get apicture diagraghm for belt replacement for a 2004 dodge ram 3500 diesel 5.9
the one above is for :
Accessory serpentine belt routing—2004–05 5.9L Diesel engines without A/C
The one below is for:
Accessory serpentine belt routing—2004–05 5.9L Diesel engines with A/C
Please do not hesitate to ask any further questions about your vehicle. Also please do not forget to rate and comment about your experience with fixya today.
45helpful
2answers
Need a diagram for fan belt or serpentine belt
Here is a diagram for a 5.7L Hemi, and 1 for a 5.9L diesel. Hope this helps!
9d0184e.jpg 5,7L HEMI
5.9L Diesel
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
