Sir,
now a system is not functionning in vga .what shall i do
Thanks for showing your interest in Fixya. Make sure the monitor cable is plugged properly or not. Remove the monitor cable and and power on the monitor. now you could see a message saying that monitor cable is unplugged. If that message appears then monitor is functioning properly. There is a problem in your display card. Replace it with new display card. Insert the new display card into PCI slot of the motherboard. Thank you....
Liebert ® Nform™ Software
GUIDE SPECIFICATIONS
1.0 GENERAL
1.2 SYSTEM REQUIREMENTS
A. All material and equipment used shall be standard components, regularly manufactured and available and not custom-designed especially for this project. All systems and components shall have previously been thoroughly tested and proven in actual use prior to installation on this project.
B. The manufacturer will furnish or supply a site-specific Critical Infrastructure Management software system based on customer requirements. The system must be a software-only solution; no substitutions will be accepted.
C. The system architecture shall consist of network interface cards that will be installed in all critical infrastructures that at a minimum support HTTP and SNMP simultaneously.
D. The system shall receive SNMP traps from managed equipment and display the alarm notification in a graphical user interface.
E. The system shall be based on SNMP Open Protocols and integrate seamlessly with Emerson Network Power, Aperture® software suite and Network Management Systems.
F. Open protocol support shall include:
· HTTP(s)
· TCP/IP/v4, TCP/IP/v6
· SNMP v.1, SNMP v.2
G. The system will have the capability of being remotely monitored and managed 24 hours a day, 7 days a week by the manufacturer.
H. The system shall have the ability to be deployed world-wide.
I. The system shall operate as a client-to-server application.
J. The Web interface of each managed device shall integrate directly into the system.
K. The system shall support Enterprise level databases including Microsoft SQL™.
L. The system shall support exporting of all recorded parametric trend data.
M. The system shall operate on a server defined by the customer. Specific server brand or function is not permissible.
N. The system shall support virtual server environments by default.
O. The system shall include at no additional cost one (1) year of Software Assurance.
