You can only get the television to recognize the external audio when connecting to its audio OUTPUT. If it does not say OUTPUT on the television where you've connected the red and white cables between it and the spear bar it is not going to work. You'll have to connect all your devices to the speaker bar with red and white cables and to the television with a yellow or green, blue, and red cable for video.
If the sound bar has the red and white spring loaded connections, simply use that output to connect to your sound bar. If your sound bar, has audio inputs that are RCA type connectors, those must be used to connect.to any line output on your receiver. If the tv has a Digital input line, you must use that. Make sure the input that you use on your receiver is switched to analog or digital input.hed
