Microwave Ovens Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brand new Sunbeam 0.9 Cu. Ft. Microwave Model SGB8901 that runs but does not heat food or boil water. Everything seems to be working on the touch pad but the unit will not heat anything. Any suggestions?
Anonymous
Level 3:
  • Master 591 Answers
  • Posted on Aug 27, 2011
Anonymous
Master
Level 3:
Answers
591
Questions
Helped
172835
Points
2033
There's a problem with the magnetron, if it's brand new return it ask for a replacement...
I have a brand new Sunbeam 0.9 Cu. Ft. Microwave Model SGB8901 that runs but I want to silence all button sounds including finish alert
Open the case and cut or disconnect the wire to the device that emits the sound. Likely it is not a speaker but a pizzo electric device. The manufacturer's do not usually include any way to turn this function off. You have to do it by brute force.
My Sunbeam Microwave SGB8901 lights up and seems to be working, but it doesn't heat anything. Is this fixable?
Only 2 years old? Hopefully you still have owner's manual, troubleshooting section should help you look for the problem. Hopefully, there is a circuit breaker, or perhaps a fuse. I hope it was not used with a metal object accidentally. No help? Check with Sunbeam Customer service, be nice, they usually are helpful.
My microwave has power but doesn't heat sunbeam model SGB8901
If it doesn't heat you nedd a technicion. orconatct manufacturer.
2helpful
I got this Sunbeam SGB8901 microwave that doesn't heat anything. It turns on, rotates drink or food, and it sounds like it's working fine, but once the timer counts down, you pull out the drink and it's...
That will either be the magnetron or the power transistors inside having failed. If you get lucky a repair shop might be able to fix it reasonably but usually it is time to look for a replacement as the repairs cost more than the new one.
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
3helpful
My brand new Sunbeam microwave model SGG5701 will not heat. it appears to be working but wont heat food or defrost
Can not find a fuse for a Sunbeam microwave model SGG5701. Where can I find one? My microwave went out after only 3 months of having it.
2answers
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
3helpful
2answers
Sunbeam microwave model SGB8901 will not stop running.....
I had the same problem, but didn't have the box anymore. The store let me exchange it for another one but that one is doing the same thing too.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
