Hi chrissybeals...
Did you lubricate the rollers with a good grade of machine oil or vasoline before you reinstalled them?
If not then that could be where your noise is coming from.
Also one other thing you can check, make sure your felt dust seal on the front of the drum is good shape and does not have worn or torn spots in it, it also can make noise.
You can also take the machine apart, remove the drum and set it off to the side, and run the motor by itself to see if it is making the noise.
Please take time to rate me
