You could have either a leak from the mainshaft seal on the backside of the primary, a leak from the transmission final drive gear seal, or the "quad" seal behind the front belt pulley spacer. Either way, I've always made it a standard practice that whenever I've got the inner primary off, I replace all these seals. It does require the removal of the inner primary and the front belt pulley. Until you get it fixed, keep a check on the oil level in both the primary and the transmission.
Good Luck
Steve
Sometimes the mainshaft leaks.. ****** ..or I have seen where shifter exits the ****** behind the primary that seal leaks ,, look under & from above ..anyway youll pull the primary..to fix good luck..check out our info at harleytalking.com....
