When i play viva pinata i click and type my name in click next and it says cannot access data. turn off power and reinsert game card wich really annoys me plz help me and makes me sad.
I have had that occur on with some games also although not with Viva Pinata that one was ok . I'd be interested to know why this happens it gets annoying after a while .
M00zyHi
I had this exact same problem. It appears to be a service running in the background that stops running. For some reason I can get signed into ALL my other Xbox Live Games for Windows games, but not Viva Pinata.
As I understand it, all you need to do is restart the service called Cryptographic Services.
To do that, go to the Start Menu, and then the Run or Search Field. Type msconfig in that box and press enter. Once msconfig opens up, click on the Services tab. Once that tab opens up, find the Cryptopgraphic Services service and start or restart it. Now try Viva Pinata again. It should work like a champ!
This mobile runs on Windows, the following software is provided for synchronization with a PC (i e PC suite):
Depending on the Operating System of your PC, you will need either Microsoft ActiveSync 4.5 or Windows Mobile® Device Center to synchronize your device with your PC.
To synchronize your device with a Windows XP PC
Download and Install ActiveSync 4.5 on your PC from here.
Connect your device to your PC using the supplied USB cable. The Synchronization Setup Wizard automatically starts and guides you to create a synchronization partnership. Click Next.
Clear the Synchronize directly with a server running Microsoft Exchange check box and click Next.
Select the information types you want to synchronize and then click Next.
Select whether or not to allow wireless data connections on your device while it is connected to the PC. Click Next.
Click Finish.
To synchronize your device with a Windows Vista PC
Download and Install Mobile Device Center on your PC from here.
Connect your device to your PC using the supplied USB cable. Windows Mobile Device Center will open. On the screen, click Set up your device.
Select the information you want to synchronize and click Next.
Enter the name for your device and then click Set Up.
have you tried deleting the profile of that specific gamertag? try it first then try recovering it.. if the issue is still there, try recovering the gamertag on a different console, if it works there, then recover the gamertag on your own console again then the issue should be okay.. hope this helps! :)
All of the level 8 pinatas are: Cocoadile, Fizzlybear, Fourheads, Lackatoad, Limeoceros, Pigxie, and Swanana. I think you have to be a level 8 or better gardener to get them.
Plz help me
exactly the same problem here
Same problem with my nintendo
Hi
M00zy
same problem here,, and with 2 other games, both Lego-:
Batman and Indiana Jones.
I need a solution, I've got a very frustrated and impatient 4 year old :-)
