Cars & Trucks Logo
Posted on Aug 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What can I do?
Joe Taylor
Level 3:
  • Chevrolet Master 2,229 Answers
  • Posted on Aug 12, 2011
Joe Taylor
Chevrolet Master
Level 3:
Answers
2229
Questions
12
Helped
908548
Points
6395
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
How to reset anti theft system on an 05
attempt to start the truck, if it does not turn over leave the key in the run position for 10 minuets the light should go out. turn key off then try and start again, if it still does not start you will have to repeat the 10 min key on 3 times before attempting to start you need to insure your battery has sufficient charge for this length of time or hook it to a charger prior to beginning
2answers
How do i reset security system on an 05 gmc envoy
Try using the door key to lock and unlock the drivers door.
How do you reset 2004 Chevy trailblazer security system without remote starter?
It should be in your manual. But if not I know a tahoe you have to turn the key to on position for 10 sec. Turn back to off and wait 1 min. And repeat 3 times
2helpful
3answers
CAR WONT START AND HAS FUEL
you have to find out if it is getting fuel.use starter fluid at the air filter and maf if does not start shortly its not a fuel problem.check for spark.if so i would replace fuel pump and filter.always check fuses first.
I’m happy to help further over the phone at https://www.6ya.com/expert/kenneth_3efc1f8510674f04
46helpful
2answers
How to reset oil light after oil change on 2005 trailblazer
  1. Turn the key to the "ON" position
  2. Press the accelerator all the way to the floor 3 times within 5 seconds
  3. You should see the oil light flash, once it stops flashing, turn the key off
  4. Wait 10 seconds before starting the vehicle, the oil light should now be reset
  5. If this doesn't reset the light, repeat steps 1-4 paying careful attention to pressing accelerator all the way to the floor 3 times within 5 seconds
Best of luck.
Greg
Car wont start
Try this Put your key in turn it on dont start wait 10 mins remove key wait 10 seconds repeat this a total of 3 times. If that dont work try a different key do the same thing. If that dont work a dealer needs to probably replace and reprogram your ignition switch and keys
1helpful
3answers
Reset button to push after changing oil
turn key on in the run position press gas peddle to the floor 3 times with in 5 seconds the wait ten 10 seconds i do these all the time
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
