It could be one of several reasons why the inside unit is not running - but the most likely reasons are 1. the breaker is off - you need to turn on breaker or reset it if it's been tripped
2. the inside motor is bad and needs replacing
3. you have a problem with the thermostat and it's not turning on the motor
4. a relay or some other electrical component is bad
Obviously, the breaker is the easiest solution and I'm hoping that's all that's wrong with your unit.
If it is not the breaker - the other things need to be checked out which may or may not require you calling a serviceman.
