Tip & How-To about Dryers
Dryers that don't work
If a dryer doesn't work, chances are it is broken. If you do not have experience with dryers do not try to take it apart as you might break it, if not already broken. If it is new, see the warranty. Get help from an expert or buy a new one.
Dryers Logo
Samsung snh9151b no power all thermal fuse and ceramic fuse checked good but still no power
Faulty door switch, Open dryer door, see if light comes on inside the dryer. If it does the door switch is good. If it doesn’t try resetting the breaker. *( dryer bulbs burn out) you may want to replace the bulb if light doesn’t come on before proceeding forward)
The start switch is another cause. You will have to unplug the dryer to check continuity.
A broken drum belt.
Turn timer on a cycle and listen for it making a ticking sound. You should as the timer is the least likely to fail, from my experience.
How can i test my dryer to find out if the motor is bad
If the drum goes around, your motor is working.
If the drum doesn't go around, the belt could be off or broken, or the motor could be bad.
Try to listen for the motor starting up as you turn the dryer on. If it sounds like it is running (an initial 'bump' followed by a quiet hum), chances are it is a belt problem.
If you can't hear the motor running, or it is a loud buzz, or there is the smell of burning insulation or smoke, chances are your motor is bad.
It is also possible that the selector switch that controls everything is not turning the motor on (bad selector) or the overheat safety switch is malfunctioning, but these need to be tested by taking the dryer apart.
taken to long to dry
IF ELECTRIC
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 • LG Dryers
does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
my kenmoer 80 series dryer has heat but doesnot dry
1. VentingMake sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
2. Thermostat
Top Dryers Experts
john h
