Tip & How-To about Cell Phones
Never leave your phone charging full nights (exception if the battery is new and needs formating). Sometimes, a lot of Nokia cell phones don`t show up the "battery full" message. This is not to worry, just leave your phone to charge maximum 3 hours.
Check your settings! Some phones have LED`s and other lights working with no particular/good use (for example: if you phone has music lights, if you disable those, your battery will have a longer life). Disable key stroke tones, you are looking at the screen when you are typing, so you don't need a beep every time you press a key, this is a really good battery saver! If you listen to music, use how often you can headphones/handsfree, this saves your battery and protects the phone`s sound parts to get broken.
• Connect your phone to a charger
and let it charge until the battery is full. Leave the phone plugged in
throughout the procedure.
Unlock the phone by pressing "*" then "unlock.
Type in the code "*#7370#" then enter your security code. The
default security code for Nokias is "12345."
Wait 2-to-3 minutes for the format to complete, then your phone will
switch itself back on.
