Tip & How-To about Computers & Internet
To speed up boot time on a vista pc click start>type MSCONFIG>press enter>go to boot tab> check the no gui boot checkbox this will get rid of the loading bar at startup and replace it with the aurora background this makes boot up about 6 seconds faster but you will not know if your pc has frozen
Disabling GUI files to speed up the
boot process.
1 Click Start and type MSCONFIG in the
search box. Press enter.
2 When the system configuration loads,
click Boot tab.
3 Locate the No GUI tab and check it.
4 Click OK to close the configuration
tool.
5 A smaller window may pop up asking if
you would like to re boot your computer now or later.
Close any open files and click Yes.
When your computer restarts, the System
Configuration tool may load, notifying you of the change.
Click the box "Don't show this
message again".
Reboot your computer and a second or so
will be saved as the system no longer has to load unwanted pictures.
Windows 7 is similar to Vista as the
programme files are loaded in parallel, unlike older versions that
loaded in series. Thereby saving boot time.
Another save is to disable Windows Home
Page Sound. That will stop the system from loading up to 600k of
unwanted noise.
1 In control panel select Sound. Click
on Sounds tab.
2 Uncheck "Play Windows Startup
Sound"
Disabling unwanted hardware devices
will save processing power allowing more power for other more
important tasks like math processing of formulae, (Games!).
1 Click the Start Menu, type
Devmgmt.msc and press enter.
2 When Devmgmt.msc has loaded browse
through your devices.
3 Devices that you don't often or ever
use can be disabled by Right Clicking the device name and selecting
Dissable.
4 To re enable the Device, repeat the
last line and select Enable.
This can save an awful lot of
processing and therefore time loading programmes that you want, not
rubbish that is not required.
Disabling unwanted Fonts.
Windows loads over 130 diferent fontsw
when it starts up. Only a handful are used. On a regular basis.
Go to the font directory, copy it to a
USB stick or CD in case you require any that you remove by mistake
and place them back where you got them from. Adobe uses some odd
fonts sometimes!
I recommend keeping:
Segoe, Calibri Common, Veranda, Arial,
Trebuchet, Tahoma, Times New Roma and Ms Sans Serif. Be sure to
keep the variants of those fonts.
E&OE
