20 Most Recent
Century 80GS Flux - Cored Wire Feed Welder Questions & Answers
Trouble feeding new wire through tip
1. Make sure that the new wire is properly locked down in the advance roller. There are grooves in this and the wire must fit in the groove.
2. Make sure the wire is properly lined up to enter the gun cable (after the roller)
3. Remove outer shield on gun and the center tip and then advance the wire until there is a few inches sticking out, then slide tip back over the wire and install the tip and shield.
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
