20 Most Recent Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas Questions & Answers
Why does my Pentair master temp reads 225 degrees
Bad temp sensor
10/3/2017 4:58:08 PM • Sta Rite Sr200lp... • Answered on Oct 03, 2017
0answers
What does error code r
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
2/13/2014 8:06:29 PM • Sta Rite Sr200lp... • Answered on Feb 13, 2014
My sta rite max e therm will not light
first ofall r 13 128 isnot an error code! blower comes on closes airswitch, then goes through all safeties, etc. need more info please ?
12/5/2013 11:20:45 PM • Sta Rite Sr200lp... • Answered on Dec 05, 2013
Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
6/17/2013 1:10:59 AM • Sta Rite Sr200lp... • Answered on Jun 17, 2013
Error code e03
This is a code for a thermal fuse open. A thermal fuse is a saftey device I always call a wax switch, It's a switch held closed by wax and if it get's too hot the wax melts and the switch opens shuting the heater down.
Changing this out will not fix the problem. It's job is to keep the heat source from hurting the heater. In other words you have fire backing up into the heater outside the fire box. This can be a fan problem or sometyhing as bad as a broken firebox. You will probally need to get a repairman involved at least to find the problem. Good luck.
5/18/2011 2:52:56 PM • Sta Rite Sr200lp... • Answered on May 18, 2011
Want to hook it up to my hot tub
Yes, these pool heaters are designed for use with a spa. They are made to accommodate temperatures for both a pool and a spa running off of the same heater. Check the owners manual for specific instructions.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
8/19/2010 6:33:46 PM • Sta Rite Sr200lp... • Answered on Aug 19, 2010
Sta-rite sr200lp heater backfiring
I would try consulting the owners manual for these pool heaters. They have a very comprehensive troubleshooting guide that you can walk through, but you will need to be looking at the heater.
8/18/2010 7:54:11 PM • Sta Rite Sr200lp... • Answered on Aug 18, 2010
Igniter
Try consulting the owners manual for these pool heaters. The troubleshooting guide is very thorough. However, it it wont fire at all and the service light comes on, you are probably going to need to replace at best case your ignition, and at worst case, your entire pool heater.
8/18/2010 7:45:17 PM • Sta Rite Sr200lp... • Answered on Aug 18, 2010
Heater isn't starting...how do I reset? Error
The users manual for these pool heaters has a very detailed troubleshooting guide. I would start there. A pdf version is below.
8/17/2010 8:33:12 PM • Sta Rite Sr200lp... • Answered on Aug 17, 2010
Sta rite pool heater error r=5?
The users manual for these pool heaters has a chart that walks you through, step by step, a troubleshooting guide. That is the best way to find a solution to your problem because it asks pretty specific questions that you have to be looking at your heater to answer. Here is a link to the pdf file.
8/16/2010 8:39:05 PM • Sta Rite Sr200lp... • Answered on Aug 16, 2010
How do you start the heater for the first time in
Make sure all gas is on to the heater and the gas valve inside the heater. Be sure all winterize plugs are in place and tight then make sure all valves are letting flow to the heater. If the heater won't start at this point be sure you have enough gas if it is LP. You need at least 30% in the tanks to get the heater to fire. Then you will have a shut off valve just outside the heater. Shut this off and you will fine a union near this, crack the union open and turn the gas back on for a few seconds till you smell gas then shut off and tighten the union back up. let it sit for 15 or 20 min. to let the gas clear then try again. If it still won't start it may be time for a repairman. I hope this helps, good luck.
4/19/2010 6:08:50 PM • Sta Rite Sr200lp... • Answered on Apr 19, 2010
Heater shuts off at 92 then cyles on and off every
This is a water flow problem. Check your baskets and your filter. Also check to see if you have a by-pass and make sure it is almost all the way closed. If these don't help you have a internal by-pass in the heater manifold and this will probally have to be replaced.
11/27/2009 9:20:38 PM • Sta Rite Sr200lp... • Answered on Nov 27, 2009
Can we install an indoor thermostat for this
There are aftermarket controls made to allow for remote operation of your heater along with the rest of your pool equipment. Jandy's aqualink system and Haywards Goldline to name two. You may want a professional opinon from a local pool store because these systems can be costly.
You could try to set up your own with a thermostat and thermistor but you would need to be well versed in installing these items as well as running remote wiring which is beyond most technicians or homeowners' abilities.
10/30/2009 4:51:57 PM • Sta Rite Sr200lp... • Answered on Oct 30, 2009
We have a Sta Rite SR400NR when we turn it on we an error code 180 then c 8 then it shuts off
Check the control wire that might be connected to the control fuse. If that wire is open the unit will only cycle thru the board information and the sit dormant until the control is called for.
5/1/2020 6:06:40 AM • Sta Rite Pool &... • Answered on May 01, 2020
Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas Logo
25 questions posted
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Sta Rite Pool & Spa
  • Sta Rite Pool & Spa
Most Popular Question
sta rite heater error code 126
  • Pool & Spa
