20 Most Recent
Sta Rite Sta - Rite 1/2hp Dura - Glas Inground Pool Pump Questions & Answers
Our pool/spa pump will cut
If the motor is very hot it could be shutting off due to a thermal safety device.
Anything that makes the motor work too hard and/or heat up will trigger this.
Blockage in the water lines
Clogged pool filter
Worn motor bearings
Lack of air flow around the motor
Weak or damaged motor windings.
A defective thermal limit switch will **** off the pump when the pump is within heat and load limits.
Sta rite SR200LP
Heater will not fire. The failure sequence is: pool on, blower on, water temperature 66 F, service heater led on, then off, heating led blinking and service heater led off, gas valve clicks open, flame starts, then gas valve closes, smells gas, service heater led on and heating led off, pool on led stays on, blower stays on for couple of minutes then off. The leds on the control Board: AGS on, cr24 on, c31 on. Water Pressure Switch (PS) closed, High limit switch (HLS) closed, Air Flow Switch (AFS) closed while trying to fire, then open, Autom?tico Gas Shutoff (AGS) closed. The combinaci?n gas control valve terminals TH and TR closed.
What should I check after this?
