20 Most Recent
Coleman Powermate 18 Volt Cordless Sander, Model# PMD8145 Questions & Answers
Coleman 18 volt battery and charger
Typically, nothing will fit it except a Coleman battery, but you can try. Be sure to test before you buy, and you will need to be really sure the voltage is the same. Be blessed.
5/22/2013 3:53:13 AM •
Coleman...
Answered
on May 22, 2013
Why does cordless drill charger light blink off after 3 seconds?
It could be a defective battery or it might just be normal for the charger and it lets you know its charging. Look in the manual for the tool and it should tell you why it blinks and turns off. If you dont have the manual i'm sure you can look it up online.
2/2/2012 4:51:44 AM •
Coleman...
Answered
on Feb 02, 2012
Safety guidelines
# Ensure that sanding belts are not too tight or too loose. Never operate a sanding disk if the paper is loose.
# Use the correct grade of abrasive material for the job.
# Ensure that the distance between a circular sander and the edge of the table is not greater than 1/4 inch.
# Do not push materials against sanders with excessive force.
# Sand only on the downstroke side of a disk sander.
# Do not hold small pieces by hand. Use a jig for pieces that are difficult to hold securely
8/27/2008 12:30:26 PM •
Coleman...
Answered
on Aug 27, 2008
I have a coleman evcon furnace and it wont work it
One flash mean ignition failure. The sequence is: T-Stats calls for heat, inducer motor comes on, igniter glows orange (look through glass), then gas comes on and burner lights, approximately 1 minute later the indoor blower comes on. If you don't see the glow, most likely the igniter is bad. If you see the glow but no flame, it's a gas problem, supply or defective valve.
Can you get a replacement Evcon PN 7956-319 board
Please see link below:http://www.northamericahvac.com/servlet/the-2287/Coleman-Gas-Furnace-Control/DetailORhttp://www.climatedoctors.com/items/item.aspx?itemid=6802187I have confirmed from a number of sites that the 7956-319 and 7956-319P boards are compatible.Good luck.
