20 Most Recent
Logitech X-530 5.1 Speakers Questions & Answers
I did some thing nd my speakers are not working
you might muted your sound or deleted the sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
I just bought logitech 5.1
if you buy a 5.1 speaker you also need 5.1 sound card that supports the speakers. although it will still work with ordinary sound card but you can't actually use the feature of the speakers. the buzzing sound can cause by loose connections of the audio cable or audio connector. you can also hear a buzzing sound if you connect it at the wrong port. just remember the color codes
green - audio out (for speakers)
red - microphone
blue - line in or audio in
black - digital audio
Well i cant hear nothing thats it. i think i move
if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume if his does not fix the problem" click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
I purchased these speakers with a laptop and also
maybe the connection of your other 4 speaker is wrong or maybe when you buy it because it has a laptop in an appropriate price you are already encourage to buy it but you didn't notice that the other speakers are broken the appropriate things to do is you should bring back that to the store where you buy it and complain about the problem and I'm sure that they will replace that or if you cannot bring back that to the store you can just fixed it to a repairing station OK....:D
How do i attach the speakers to my computer
The manual for you speaker system is located here;
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8793&p_sid=jIAa2a-j&p_lva=8040§ion=troubleshoot&crid=439<_product_id=211&tabs=1%2C3%2C2%2C5&p_search_text=X+530
On page 2 of the manual it says that all of the speakers plug into the subwoofer, then the subwoofer is pluged into an ac power supply, then # 4. on page 2 of the diagram shows that the Audio input cable to your PC is the green, black & orange plugs!!!!! YAY!!!
If you do not have a Dolby 5.1 sound card with green black and orange plugs, you will have to buy one. The can be had for a little as $15....
Thanks,
James
-----------------please vote 4 thumbs up 4 me!!!--------------------
Where on my hp pavillion laptop do i plug in my logitech x-530 sp
If you search the lower base sides of your laptop you'll find two circular sockets, one with the symbol of mic and other with that of a headset speakers. Plug in to the second one and there you go :)
Please come back and rate my solution if it turns to be helpful for you and also if you need more clarification.
Thnx
How will my speakers plug in to my hp pavillion
Hi there stormy,
Regarding the compatibility of your speakers, I know for a fact that the HP Pavilion Slimlne s5380t is integrated with Intel HD audio 7.1 surround sound.
This means that it has the capacity to handle 2 speaker stereo or 2.1 speakers, your 5.1 surroud sound & for the home theatre experience it is also capable of handling 7.1 surround sound.
I hope that you get on well with your neighbours, ha.
kindest regards,
Ste.
