20 Most Recent
Digital Blue Disney Flix Camcorder (White) Questions & Answers
We need the apple mac software for the disney
There isn't any.
But all you need to do is plug the camcorder in, and the Mac should mount the camera as a hard drive.
You'll see it come up in the Devices menu, in the sidebar of any Finder window... unless you've deliberately switched off "show mounted devices".
Double click on the new device in the list; it will be under your HD and have the dark sideways triangle that shows it can be unmounted.
Inside you'll see file folders for music, movies, etc.
You can copy the movies to your hard drive, and watch them with the shareware app VLC... it will view almost anything,
Or of course you can try iMovie,
Computer doesn't see disney flix camera
Use a sd card in the flix, for the most part, camera's, phones, if they have a sd card,or memory card, the pc might see the card and load it as a drive, as you said you looked under my computer.
You should also get a cheap sd card reader, a few bucks,$5-6,
this way, if your pc does not see the card, you can put the card into the reader and plug it into the usb port, and import/export all day long. Not sure if this flix can format the card,read your manual,
but always format the card once(new card) with the flix, and never format the card with windows. Hope this helps.
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps:
Locate the original remote control that came with your VCR.
Look for a button marked as C.LOCK or LOCK.
Press this button. This should allow you to exit the safe mode3.
If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
Movavi video editor 11
which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
Rca vhs camcorder cpr300 won't playback or record
This may be bad belts, and what you should check for is the belts on the side of the tape deck toward the lens and pickup(front), and the drive belt in the middle. All the belts are under the circuit board, so you need to remove that to get at them, and then you can replace them with rubber bands of same or slightly smaller size. Use a screwdriver to help get the old belts off, and put new ones on. (In the tight space)
Then check if the tape deck opens and closes, and see if the tape moves when you hit play/record. If you put in a tape you know has a video written onto it, then put that in, and try to play it. If you get a noisy or staticky picture, then try wiping the video head drum(Big shiny cylinder that spins, with the small slits in the side.) with some alchohol and a glasses cleaning cloth or paper. Also, wipe the audio/control head, the silver box that the tape runs across just before it goes by the black roller. Also, check for gunk or obstructions that have gotten in the mechanism of the tape deck in the back. Make sure the video drum is spinning, and that the tape is pulled out of the cassette by some small rollers and wrapped around the video drum DURING playback/record. I say 'during' because some camcorders will retract the tape back to the cassette for fast forward and fast rewind.
I hope you get your camcorder to work! Thanks! 73
Sincerely, Beauregard42. (<-- My YT channel where I have some tech stuff)
Problem with Panasonic Camcorder NV-DS28
From speaking to a repair centre this is a very common problem with Panasonic camcorders.
I got the impression it was a panasonic problem with a connector that needed either cleaning or replacing.
There are 2 fixes, one is cheap quick and temporary.
The other involves sending the camcorder away to be professionally repaired, it should cost the minimum fee, which was £50 in 2007.
As for the cheap version, it involved turning the camcorder off and hitting it against a copy of the yellow pages and turning on again. This worked for long enough to record my 2nd daughters birth.
I just bought a ONN Camcorder 1.44 digital screen with 2x digital zoom.
Question edited for clarity.
Question moved from '2X Computers'.
ONN is Walmart's Bargain basement brand made in China. The manuals are written in Chinese and translated in a very brief way by non fluent translators. The best option is to go back into Walmart Camera section and ask one of the associates to show you how it works. Make sure it is fully charged and take the manual with you.
