20 Most Recent Sherwood RX-4105 2-CHANNEL REMOTE-CONTROLLED STEREO RECEIVER Questions & Answers
Why does it turn on sporadically, stay on briefly, then turn off?
Sounds like a defect to me return it for a working model.
6/2/2015 1:44:16 AM • Sherwood RX-4105... • Answered on Jun 02, 2015
2answers
Sherwood RD 7505 - video button under the input area doesn't work when pressed. Can't change the input to have TV come through the speakers.
Hi, Please power cycle your tv and check that it's connected as it used to be when the video-button was working for you. You can also power cycle your sherwood device before attempting your initial procedure/button press again. If it still does not work, please test that your speakers are able to function with other items in your location in order to eliminate the speakers as the potential cause of the issue. Thank you.
11/27/2022 9:22:36 PM • Sherwood... • Answered on Nov 27, 2022
My replacement remote for the Sherwood RC 125 will not work. I checked the signal with my digital camera and the lights are constantly blinking. Can I fix this?
No. The remote control is damaged. Its control IC has the fault. It can't be replaced. It can't be repaired. Buy an other one. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
7/19/2015 4:01:56 AM • Sherwood... • Answered on Jul 19, 2015
How to service/lubricate (and what with)the disc tray on a Sherwood CDC-5010R 5 disc multiplayer
try a small a squirt of silicon spray on the moving parts
11/23/2014 10:33:09 AM • Sherwood... • Answered on Nov 23, 2014
5answers
Looking to get the region
Hello there, I am very familiar with this Sherwood Blu Ray player and unfortunately it is impossible to unlock the region on the player. It is locked at a hardware level and is physically impossible to unlock. There aren't a ton of blu ray players on the market that are region free actually. Yours is definitely not one of them.
So sorry to be the bearer of bad news, but it is definitely not possible.
Thanks for your time,
Tim
7/15/2009 9:26:18 AM • Sherwood... • Answered on Jul 15, 2009
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/25/2024 3:46:43 PM • Televison &... • Answered 15 hours ago
2answers
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
The most obvious reason is an overheating issue in the Power Supply board. There are other ideas here, but you need to take it to a television engineer to diagnose https://www.google.com/search?q=television+will+suddenly+turn+off+every+4+minutes ..
4/25/2024 3:46:35 PM • Televison &... • Answered 15 hours ago
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered 3 days ago
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered on Apr 21, 2024
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered on Apr 21, 2024
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered on Apr 21, 2024
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered on Apr 20, 2024
Sherwood RX-4105 2-CHANNEL REMOTE-CONTROLLED STEREO RECEIVER Logo
4 questions posted
Top Sherwood Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sherwood Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sherwood Televison & Video
Most Popular Question
standby light but remote doesnt turn
  • Televison & Video
