20 Most Recent
Elite 45 in. LCD TV Questions & Answers
Elite SL3000UL stopped working after a thunder storm. The unit has power but no led's are lit.
It is worth checking if there is a fuse inside the Elite SL3000UL. If there is, the unit may have been damaged by a lightning strike or a power surge. If there is no fuse, it could still be a control board failure, a surge suppressor failure, or another related issue. To investigate further, you will need to consult the manufacturer or contact a certified electrician for help.
Kenmore Elite HE5T Front Load Washer Error Code F22, Door Latch, i replaced with a new one, still have the same Error Code, does this mean i have a faulty CCU?
Hi, if you don,t have a manual to refer to, take the number on your washing machine, this will indicate the model and make, and locate your helpline, the number should also be on your washing machine, either next to the door, or on the back or bottom front. i hope this helps
