Question about Elite Televison & Video
Nothing on my kemore elite dryer HE4 works except for the drum light
Model 110.85088400
Posted by Drema Boyd on
2 Related Answers
Anonymous
SOURCE: Kemore Elite HE4 Dryer
With mine I found that some of the plastic front buttons had come loose (?!?) and at least one was always pressig down - when took the front panel completely appart, and used a plastic chopstick to lightly press the real buttons inside, everyhing worked! Some of the buttons had come loose (realy cheaply attached, so no wonder). Currenty letting the glue dry - lets see if that works. WARNING:  Don't try this yourself unless you are an electrician or computer service professional! Even turned off and unplugged, any electrical appliance is still dangerous!
Posted on Sep 06, 2008
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Posted on Mar 23, 2010
2answers
What do we do to address thumping noise in Kenmore Elite HE4 Dryer?
It is probably one of the idler wheels it rotates on. Look for a flat spot and if you didn't replace the drum your self ask for your money back.
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
2answers
Hi! juysu
Please check the power cord, by checking if there is 240V on the power terminals inside the back of the machine where the power cord is connected.
InMrFixIt
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
HE4 Kenmore Elite Dryer error code 4e
If you have ever removed the lint filter area completely via the screws that hold the plastics in so you could clean it then remove it again and insure that you plugged in the two wires that go to the strip sensor.. (moisture sensor)
Kemore Elite Dryer Repair
at the bottom of the unit there will be 3 torks screws remove them and the panel will open so you can see the insde and the heating element box...UNPLUG FIRST!!!
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Televison & Video Logo
Top Elite Televison & Video Experts
ENFORCER
Larry
Are you an Elite Televison and Video Expert? Answer questions, earn points and help others
