20 Most Recent
A4tech SWOP-3 Mouse Questions & Answers
Mouse lights up when plugged
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
if applicable
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Hi, I have a4tech hs-6 headphone and i am getting a humming sound. Please help me
Remus Calinoiu wants answers to this question
NO PC stated, so gets hyjacked anyway.
if it is a PC and I see those are 32ohm 3.5mm phone plug electromagnet head phones.
The problem is caused in this case by bad connection or the headphones shielded, wire 3.5plug is damaged
If you try other phone (any) and it works ok,you know it is not the PC problem.
buy $1 earbuds at a Dollar store and prove that, for $1
the other cause (I cant see you or it) if the head phone wires
are long and land near a WALL wort transformer power pack it sure can hum. the cure is easy move the PACK away from phone lead in wire. even desk lamp power pack can do that.
How can I fix an A4tech keybord is working but hard to type?
no PC stated
no OS stated or windows version if windows at all.
A4tech makes many models, none stated (sticker on bottom hint)
vast models, even old PS2 keyboards from long aga to USB keyboards,
seem time to buy a new keyboard if not wireless
if wireless, the batteries are dead , like most are now... right.
G9300 is wireless , THAT wild guess of over 100 models made by THEM>
if USB test in on 2nd PC, if works there
try all USB ports on the bad PC.
if all fail then your OS is corrupted or the USB port drivers or the keyboard driver is corrupted.
is OS windows 7/8/ or 10 , older versions not worth using, a fact.
Installation Problem
windows 10 some times installs the wrong drivers, there is a windows fix https://www.laptopmag.com/articles/disable-automatic-driver-downloads-on-windows-10 follow this information but it will turn off driver update, remove the driver windows has installed and turn off pc/laptop and reboot, when systerm is running install the driver from the cd, it should install and windows will stop trying to update this, if you need to update any drivers in the futer do this maunaly in device driver settings.
