20 Most Recent
GE GFWH1400DWW Front Load Tumble Questions & Answers
GE FRONT LOAD FILLS BUT WONT START
the first thing that comes to me is the door switch,if it is faulty the machine will not go any further,try pushing the door a couple of times and see if it will start,if not try holding any two button until you here a beep or for 20 seconds ,or hold and push the stop start button for same,this a reset for any white goods.if this fails please come back to me,adrian....
GE WASHER MODEL GFWH1200HOWW RUNNING EXTRAAA LONG ON WASH CYCLES??
Hello Heather
Good to see you again.
Also check the small strainers on the water connectors. They can block up with limescale and debris. While the connectors are off, turn on the water into a bucket or a sink. You should have a VERY powerful jet of water. Anything that will reduce flow will lengthen the fill time and therefore to total wash time due to fill and rinses. When it pumps out, also check you have good flow in the drain hose and items can jam in the ridges and catch lint enough to block them almost completely.
One clever thing to do is whilst the water inlet connectors are off, unlock the drain hose, unhook the part that makes the hook, put the round connector in the hose and wrap a tea towel around it. Get someone to turn the water on full bore whilst you are gripping the two hoses together. Run it for a full minute. Water will be flushed into the machine through the pump in reverse. Put everything back and run a rinse and spin with nothing in it, look at all the black lint that is pumped out! I did that once at work and found an apple stalk that had lodged across the ridges of the drain hose which had 90% blocked the pipe.
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
Winterizing a washer in a summer cabin
Just remove the drain hose from the drain upstand pipe and lower it to the floor. It will empty the pump or water.You can also drop a pint of car anti freeze into the machine just to be sure if you wish.
How to reset a GE washing machine WPDH8900J1WW
I understand your frustration. It sounds like your GE washing machine is having some problems. Resetting the washer may help to fix the issue. Here are the steps on how to reset a GE washing machine WPDH8900J1WW:
1. Unplug the washer from the power outlet.
2. Wait for 2 minutes.
3. Plug the washer back in.
4. Turn on the washer.
5. Select a cycle and press the start button.
If the washer still does not work, you can try resetting the drum motor. To do this, follow these steps:
2. Wait for 1 minute.
4. Open and close the lid of the washer 6 times within 12 seconds.
5. Close the lid and press the start button.
If the washer still does not work after resetting the drum motor, you may need to contact a qualified appliance repair technician.
Here are some other things you can try before resetting the washer:
* Make sure that the washer is properly leveled.
* Check the water supply hoses for leaks.
* Clean the lint trap.
* Check the detergent dispenser for clogs.
I hope this helps!
My GE top load washer model 110.27062603 will not run through a full cycle. Sometimes it washes, but 17 minutes showing, jumps to 2 minutes, then shuts off with 'OL' error code.
OL = Overloaded.
Is the Washer overloaded? If OL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent.Feb 24, 2020
OL - Error Code - Top Load Washer - Product Help - Maytag
Maytag
https://producthelp.maytag.com > ... > OL
The washer has ol on it at the end - Maytag Bravos quiet ...
iFixit
https://www.ifixit.com > Answers > View > The+washe...
Oct 6, 2014 · 2 answers
First, OL stands for "Overload", so in other words, the washer thinks the tub is too hard to move because it's overloaded and the motor is ...
OL code all the time even with very small and light ...
Sep 28, 2016
Why washer stops and gives code "ol" - iFixit
Nov 30, 2016
at the end it says OL - Maytag Bravos quiet series 300 ...
1 answer
Dec 29, 2022
OL code showing . - Kenmore 110 Series Washing ...
Sep 19, 2017
More results from www.ifixit.com
GE GUD27ESSM1SS stackable washer dryer stuck in spin cycle
A top-load washer tub is usually supported by four suspension rods. If one of the suspension rods becomes dislodged or breaks, the control board may stop the spin cycle several times to try to balance the clothes. Suspension rods will often come in a set of four and it is recommended to replace all four of the rods at the same time to reduce uneven wear.
How do I get my GE WH38X10017 drive shalf or shifter it to open?
The TRADESMAN Auto Rotisserie is perfect for body shops, race car fabrication, and classic car restoration. However, it is built for the professional shop or serious do-it-yourself. This equipment is all about saving time and money and working safer and more intelligently.
