Keyboard popped out and I can't figure out how to
It is a ribbon connector, that hasn't broken or ripped?
There will be a small white recepticle with two levers sticking out each side. They are very small, but they will be the only thing that moves, so you can find them with a bit of poking around)
Pull the two levers forward to where the ribbon will be comming into the recepticle. (see how it aligns together when the keyboard is in it's proper position.)
Slide the end of the ribbon into the recepticle as far as it will go, and with it in place, push the two levers on each side back into their locked position, which will be back in the same direction the ribbon moved to enter the recepticle.
Give the ribbon a tug to see that it's firmly held in position; then before snapping it back into place, try it out by turning on the laptop and testing Caps Lock, or Num Lock keys to see if the indicator lights change.
If the keyboard dosn't work , be shure the ribbon is not dammaged, and that it is seated in the recepticle as far as it can go.
A little practice and you'll be a master.
Good luck with this.
1/27/2010 2:31:19 AM •
Averatec...
Answered
on Jan 27, 2010
