FixYa.com
GE  18,000 BTU 230 Volt Electronic Room Air Conditioner, AGW18DH
All Products > GE > Air Conditioners
Problems with GE 18,000 BTU 230 Volt Electronic Room Air Conditioner, AGW18DH?
Search inside GE 18,000 BTU 230 Volt Electronic Room... Knowledgebase
Troubleshooting and Support
Solved Problems for GE  18,000 BTU 230 Volt Electronic Room Air Conditioner, AGW18DH RSS Feed Post a New Problem
Will constantly running a central AC...
Will constantly running a central AC system on a very cold setting, such as 65-F, damage the system?
1 Solution
What would cause the outside part of my...
What would cause the outside part of my air conditioner to frost over?
1 Solution
How do i know if my cooling system can be...
How do i know if my cooling system can be repaired or if it is time to replace it?
1 Solution
How often should you change the filter on...
How often should you change the filter on your heating and AC unit?
1 Solution
How much does a mid-price range central AC...
How much does a mid-price range central AC cost installed with an electric heater including ducting in a 1300 square...
1 Solution
I am looking for a digital thermostat that...
I am looking for a digital thermostat that can run two AC units simultaneously or is there another solution using one...
1 Solution
Heat pump trips circuit breaker
The heat pump in my air conditioning system trips the circuit breaker... what do I do?
1 Solution
View All
Tips & Tricks
Post a New Tip
GE Contact Information
Main support number1-800-626-2005
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
