20 Most Recent
Kyocera "FS-3540MFP Copier, FS3540" Questions & Answers
How to fix the error code c0150
You will need a service engineer to fix this problem it will either need a new main board or a firmware update
0150. Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
3/16/2015 11:05:06 PM •
Kyocera...
Answered
on Mar 16, 2015
How do I pre-program fax numbers?
if you are connected to network print you can access the web interface by typing the ip address of the printer into any web browser on the network. then go to the basic tab in command center and look for the address book. If you are connected USB this will not work. I recommend network connectivity so you can administrate the unit from the browser.
9/30/2014 5:58:43 PM •
Kyocera...
Answered
on Sep 30, 2014
What is code Kyocera 3212i error code C3800
The error code C3800 on a Kyocera 3212i printer indicates an AFE error. This error occurs when writing data and reading data does not match 3 times continuously, or there is no response from AFE for 100ms. The following steps can be taken to resolve this issue:
Check the connection FFC is not connected properly. Or it is faulty. Clean the FFC terminals of the following FFC and reconnect them.
If the issue persists, consider contacting a Kyocera technician or service provider for further assistance.
Kyocera Printer wont scan
Check Network Connection: Ensure both devices are on the same network.
Restart Devices: Power cycle both computer and printer.
Verify Scanner Settings: Confirm correct scanner selection.
Update Drivers: Install latest printer drivers.
Firmware Update: Consider updating printer firmware.
Inspect Cables: Check all connections.
Contact Kyocera Support: If issue persists, reach out to Kyocera's support.
