20 Most Recent Samsung SCH-a670 Questions & Answers
you cant cingular is a gsm network and verizon is cdsa
Samsung SCH-a670 | Answered on Jul 16, 2013
You can unlock a SAMSUNG A670 using unlock code. You can get the unlock code for your mobile phone from www.Theunlockspot.com at affordable cost with easy step by step unlocking instruction.
Samsung SCH-a670 | Answered on Jun 28, 2012
Hello, Verizon has to repair your phone for you!!! I had the same exact problem and they said it was a defective part and that they would fix it... Just go into the store and tel them they have to because it is a known default. I just had to get mad. After i did that i got alot more help. Good luck!!!
Samsung SCH-a670 | Answered on Mar 31, 2012
Good day!!!
if your cell phone have a direct USB features you can isert it directly on the computer to transfer some files...
if you don't have direct USB drive but your cell phone have a memory card you can insert it to the card reader and insert it to computer to transfer important files..
but if you don't have both unfortunately there's no other way rather than repair your c.p by replacing LCD screen..
Thank for using fixya and don't forget to rate my answer and write a testimony..
Samsung SCH-a670 | Answered on Jul 15, 2011
Send all the contacts via bluetooth or send it through text..
Samsung SCH-a670 | Answered on Apr 14, 2011
try changing the battery with a new one or or you are sure works and see if it works if not send it for repairs
Samsung SCH-a670 | Answered on Oct 24, 2010
Your gonna need to buy a really cheap phone exactly the same model as yours. You should definitely use the internet to do so. After doing so either find a local repair facility and have them swap the boards or buy the Precision Electronics Tool kit from Lowes or Home Depot and do it yourself...
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Samsung SCH-a670 | Answered on May 01, 2010
ur cell's mike has gone out.. try repairin it...
Samsung SCH-a670 | Answered on Apr 12, 2010
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Samsung SCH-a670 | Answered on Apr 03, 2010
Hi chad0872,
First and foremost, you can't do anything if you don't have all of the components needed to do the job. You will definitely need a computer. More importantly, you will also need a Micro SanDisk and TransFlash to SanDisk adapter. The Micro SanDisk is a very small device, approximately the size of a chip. The disk is placed in your phone to store your phone's items for transfer. The TransFlash to SanDisk adapter is used to access the SanDisk files on your computer. Your SanDisk should be at least 256MB for sufficient storage space.
Once you've established and obtained everything you need, you can now begin the initial transfer process. Insert your Micro SanDisk into the phone where your ringtones are stored. Access the Media Folder or Content Management folder in the phone. Highlight each ringtone file you want to transfer. Open the Options' section available for the ringtones and opt to move your ringtones from the phone's storage to the memory card. Once the transfer process is complete, remove the memory card from the phone
Now that you have moved your ringtones to the Micro SanDisk, place the Micro SanDisk into the TransFlash SanDisk. Insert the TransFlash SanDisk into your computer. This expandable memory slot can usually be found in the from of most laptops and next to the USB slots on the front panel of desktop model computers. Once the insertion is detected, your computer's AutoPlay dialog window will appear or an import options will be given. When the ringtones' window opens, drag and drop the ringtone files from your Micro SanDisk to your computer's desktop screen.Then transfer it to your phone,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Samsung SCH-a670 | Answered on Mar 06, 2010
Samsung SCH-a670 Logo
91 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SCH Samsung
  • SCH Samsung
Most Popular Question
phone broken in half need help fix
  • Cell Phones
