20 Most Recent
West Marine Ensign Molded Boat Seat Questions & Answers
I have a 15 hp 2 stroke mercury outboard. When I
it is getting flooded ,dont ask me why, as im not there to check it out but if when first prmeing you stop pressing the bulb as soon as you feel any pressure at all, you will probably find it will start up straight away
1/13/2011 7:56:46 PM •
Boating
Answered
on Jan 13, 2011
Want to replace the trim/tilt motors on my 1995
no. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
1/2/2011 4:12:06 PM •
Boating
Answered
on Jan 02, 2011
Hi.For repairing boat Kelt 760 DL need information.Studs are
That is a nice boat, but a major repair. If you have rotten wood, and need to replace it, and need to remove ballast, you have a big job on your hands. I don't think the wood members are called studs, I think they are thrwats or something like that. Are they bent? As in 2x2 oak? A boat yard will tell you how much it will cost, you can do it yourself, and you can't, You need special tools for this, A big steamer, and somebody with hands on knowledge. The materials are probably the cheapest part of the job.
2/22/2010 12:09:14 PM •
Boating
Answered
on Feb 22, 2010
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
