20 Most Recent
Behringer cx2310 super-x pro crossover 2-way/3-way Questions & Answers
I need to connect a crossover for live performance.
I'm not quite sure exactly what you are referring to. Crossovers are generally part of your speaker system, used to send the correct sound content to the driver designed for it, meaning the woofer, midrange, or tweeter. For more information, please visit my website at audioserviceclinic.com. Thank you.
Behringer cx2300
follow this instructions and fix it. God bless youInstructions
Plug one end of a shielded input cable into the mixer's main
output, and the other end into the crossover's input. The cable
connectors will be dictated by your particular mixer and crossover, and
will be either standard 1/4" or 3-pin XLR connectors. Consult the
owner's manual of all components for specific details and
recommendations.
Plug another shielded input cable into the crossover "high"
frequency output, and the other into the crossover's "low" frequency
output.
Plug the cable coming from the crossover "high" output into
the channel one input on the stereo power amp, and the cable from the
crossover "low" output into the channel two input of the power
amplifier.
Plug one end of the unshielded speaker cable into the power
amp channel one speaker output, and the other end into the horn tweeter.
5
Plug one end of the second unshielded speaker cable into the
power amp channel two speaker output, and the other end into the
woofer. The connections are now complete.
Please help! Behringer KX1200 master volume stops past 4 and no lines work just fx return
Also how do I reconnect the fan?
It sounds like you may have a broken potentiometer (aka volume knob) for the master volume control. If that is the case, you would need to replace it with a new one (or take it to an electronics technician to diagnose and repair).
Regarding the fan disconnection, this likely isn't causing your issue but you would still want to reconnect it as it keeps your amplifier cool while in use. Reconnecting is fairly straightforward - all fans have 2 or 3 wires that connect to corresponding terminals on the amp. Just make sure you don't mix up which wire is positive and negative, and make sure they are connected firmly and securely.
Behringer EP1500 amp does not produce full loudnes
Please test the loudness of your device with a third-party decibel meter. This will give you a clear measure of whether the loudness of your device is changing with increase in volume. It could be that your surroundings are absorbing the increased sound.
Thank you.
How to get 5.1 sound. to an external audio card?
The channels are setup according to the model. If you have stereo (2 channel L/R) then you cannot get 5 channels out of it. To do this you need a card that is 5.1. If your card IS 5.1, then i would enable the channels in the audio mixer for the card.
I have a Behringer pmp1280s. It was working fine 12 months ago. I got it out again today. Everything lights up fuses are fine. level lights work. No sound out of speaker outputs
I doubt that there is a problem with the unit. Usually people have problems with their cables or the speakon plugs themselves.
Unscrew the connector that is used on both ends and double-check their connections. Sometimes the screws that hold the heavy gauge wire in place, come loose. Also make sure that they are in the right places. Sometimes you have 4 connections. Make sure they are in +1 and -1 connections. Every once in a while you'll find a quirk unit that requires you to use +2 and -2 instead. Look at the back of the amp. It should tell you which numbers it uses. Make sure you check the same thing on the speaker end also. If you have a meter or continuity checker, use it to make sure it's wired right.
This is a professional piece of equipment. They don't go bad easily. Make sure you tighten those connections real good and that you pay close attention to the engraved numbers on the speakon connectors. (That is if they are quality connectors. The cheap ones may NOT tell you the numbering or the phase, ((+ or -)). Hint: The negative one is always closest to the outside of the plug. You'll have to study it to understand that. The screw terminals on the inside have 'walls' on both sides of it. Those are the + connections.
Also, check the switches on the front. You may have one of the switches in the wrong position or setting. Also if you're using phantom powered mics, you have to turn the phantom power on or else they will not work. Hope this helps.
