20 Most Recent
Trek Mystic 16 Questions & Answers
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Ineed to know how to mount the computer on the frame of my Trek 3.1 road bike.
You have several options:
1. Follow the instructions for the computer that came with it or that can be found on the manufacturer website.
2. Go to a bike co-op for help
3. Have a bike shop install it.
4. Provide some useful info here such as the make and model of the bike computer. Without that nobody can help you.
11/6/2019 1:14:24 AM •
Trek Cycling
Answered
on Nov 06, 2019
How do I remove the front tire of my Trek Fuel Ex 7 29?
Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
10/2/2017 8:10:21 PM •
Trek Cycling
Answered
on Oct 02, 2017
Price of mens bicycle trek 7.1 15"?
The price is between $1,760 and $1,800.for more details check www.trekbycirclesuperstore.com the go to search on the page to get the price for your choice bike.
1/12/2017 12:03:53 PM •
Trek Cycling
Answered
on Jan 12, 2017
