20 Most Recent
Sapphire 100293-2GL RADEON HD 5570 2GB DDR3 PCI Express 2 0 x16 HDCP Ready CrossFireX Support Video Video Card Questions & Answers
Does hd 5570 1 gb
This motherboard will support ATI HD 5570.Because it has one PCI Express x16 slot.
Thanks for using FixYa.
6/12/2011 6:06:52 AM •
Sapphire...
Answered
on Jun 12, 2011
I have an asus m2A vm hdmi mobo. I needed a better
you will have set your computer to failsafe defaults or optimised defaults first to get your resolutions to there defaults first
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! red x right click select reinstall drivers if your computer came with a motherboard disc the drivers could be on it or you could download cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html This release for all Radeon family products updates the AMD display driver to the latest version. This unified driver has been further enhanced to provide the highest level of power, performance, and reliability.
hope this helps
5/30/2011 6:11:33 AM •
Sapphire...
Answered
on May 30, 2011
When I inserted the new
Check the BIOS settings and see if there's a way to disable the onboard graphics card, from shutdown start tapping F2 (for most computers the Del key for some).
Once in the BIOS look for the devices or onboard devices and check if the graphics card control is there.
Usually, the onboard card automatically disables once it detects a GPU into the AGP or PCI-E port, please make sure that you have the card plugged in tightly to the slot and check if there's a small cable additional for giving power to the Graphics card.
If you can also try to remove and reinsert the Graphics card from the slot.
Hope this helps!
5/30/2011 3:02:39 AM •
Sapphire...
Answered
on May 30, 2011
WHAT VIDEO CARDS ARE BEST IN VIDEO EDITING AND
Unless you are using the absolute latest versions of the program - in that case, since they can use hardware acceleration, the best cards are indeed the most powerfull ones - you should have no problem using practically every video card from the mainstream line of both ATI and NVIDIA. For better driver performance get a RADEON HD5770 with 1GB of DDR5 memory.
4/24/2011 12:46:40 PM •
Sapphire...
Answered
on Apr 24, 2011
IS THE SAPHIRE 5570 2-GIG
Your board has a PCIe X16 slot so the card will fit. It requires a 400w power supply so, as long as you have enough power you're good. It also has support of Win XP, Vista, and Windows 7.
4/22/2011 10:46:04 AM •
Sapphire...
Answered
on Apr 22, 2011
If I were planning on
470 or Higher would be the minimum. I would look for a 500 if I could find one.
2/28/2011 3:34:18 AM •
Sapphire...
Answered
on Feb 28, 2011
Can the SAPPHIRE 100293-2GL Radeon HD 5570 be used
As long as your motherboard supports this card. There should be no problem using this card as the primary video card. You might have to change a setting in the BIOS to make this video card to primary.
1/27/2011 7:32:06 PM •
Sapphire...
Answered
on Jan 27, 2011
How do I cancel my membership to sapphire
You need to contact what ever sapphire is ? there would be a support page on their web site or a contact link somewhere on their web page. Not sure what sapphire you are referring to is ? Is it Achocol or is it a graphics card or something else ?
11/2/2014 11:14:33 PM •
Sapphire...
Answered
on Nov 02, 2014
HD6870 DVI
Use the manufacturer's utility to check the temps. I would first swap out the DVI cable to make sure that isn't the issue. Then try a different monitor/TV to eliminate those as the problems. If you have onboard VGA you could also switch to onboard VGA to make sure the cable is good as well as the monitor.
1/8/2014 10:37:47 AM •
Sapphire...
Answered
on Jan 08, 2014
Nearest repair center
Your graphic card got faulty pins or it must been overheated. Try using it after 6 hours after resetting CMOS.
11/12/2013 7:26:29 AM •
Sapphire...
Answered
on Nov 12, 2013
