20 Most Recent Haier ESA3109 WallWindow Air Conditioner Questions & Answers
My ac is directly under
The "E1" code indicates a compressor sensor failure. Did the dripping water from above cause the problem? Possibly , but there's no way to prove it. If you'd like to order the part and replace it yourself, call 800-313-8495. Have your Model Number & Serial Number handy when you call. If the unit is still under warranty and you have your dated Proof of Purchase call 1-877-337-3639.
Hope this helped you and tanks for choosing FixYa.
8/8/2011 3:47:24 PM • Haier ESA3109... • Answered on Aug 08, 2011
The front of the unit behind the filter freezes
the reason for the coil (behind the filter) to freeze up is 'low air flow' over the coil, which is usually caused by a dirty filter AND/OR the coil itself.
Be sure the coil is clean and not clogged up. Shine a flashlight into the fins and be sure it's clean.
If it is clean then you need to look at the fan motor. Is it blowing correctly? Is it cutting off at times?
Low air flow across the coil is the main problem with coils freezing up, although less likely is a 'low refrigerant charge.'
I would make sure the coil was clean and the motor was blowing air across it in the proper manner.
8/5/2011 4:23:20 PM • Haier ESA3109... • Answered on Aug 05, 2011
I HAVE STYROFOAM INSIDE THE
Is it packing or is it insulation? If packing, as in you just bought this unit and have never used it, remove it.
8/5/2011 2:16:08 AM • Haier ESA3109... • Answered on Aug 05, 2011
2answers
WATER DRAINING UNDER LEFT FRONT...other than that
The window unit needs to have a god tilt on it aiming it outside,and remove the unit and clean the unit out with a water hose ,make sure the bottom of the ac unit has all the debris removed.
8/1/2011 12:17:04 AM • Haier ESA3109... • Answered on Aug 01, 2011
Hello, I have a Haier
Its not that simple You need to vacume the system down before you can chagre it again. You will need a tech to do that for you . sorry but thats the way its done
7/23/2011 9:40:52 PM • Haier ESA3109... • Answered on Jul 23, 2011
The AC is on. Set
You can try unpluging it to reset it .. this is a tough one as i not to certain.. But try that wait for about a munite nbefore you plug it back in.
7/19/2011 2:57:35 AM • Haier ESA3109... • Answered on Jul 19, 2011
BRAND NEW AC IS FREEZING
Temp set to cool. shut it down for a hour or so . close all unused rooms. set tstat to mid range and start it up again . when it cycles off and its still to warm in the room trun the stat down tell it comes on again. Also check the filter and make ceratin it is clean.
7/15/2011 10:57:44 PM • Haier ESA3109... • Answered on Jul 15, 2011
Hi, my a/c is less
The refigerant is still moving thru the system normal. It can take several minutes to equalize the pressures.
7/8/2011 5:07:35 PM • Haier ESA3109... • Answered on Jul 08, 2011
The top and bottom coils ice up and there is no
Hello, the coil will freeze either due to low airflow or a low refrigerant charge. Many times a dirty air filter or dirty evaporator coil will cause ice to form and cleaning both will fix the problem, however if the unit appears clean then a low refrigerant charge is the problem and the unit will need to be recharged.
7/7/2011 3:14:32 PM • Haier ESA3109... • Answered on Jul 07, 2011
Error code E1. Please tell me what E1 refers to.
Unfortunately. Haier does not have an online manual for your model AC. However, if you contact their Customer Support Dept 1-877-337-363, they can tell you what the code means and supply you with an Owner's Manual for future reference.
Hope this helped you.
6/28/2011 3:12:04 PM • Haier ESA3109... • Answered on Jun 28, 2011
When I turn the air
Hello, you would need to take the top cover off the AC and check the fan, usually the hub of the fan breaks and becomes loose or sometimes just the clamp comes loose and the fan hits the housing. If the fan is cracked then you would need to replace just the fan on the unit. Here is a link or parts to your ac http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/ESA3109.aspx.
6/13/2011 10:04:13 PM • Haier ESA3109... • Answered on Jun 13, 2011
2answers
My power went out after
E1 might be a stuck key on the keypad... they are sometimes flakey .. maybe water getting into the keypad ... at any rate the remote control usually still works .. eventually sometimes the key pad starts to work again (maybe when it dries out)
So, based on solutions from those other sites, I pulled off the front panel, turned it over and removed the 4 screws from the back of the control pad (not the six screws on the outer perimeter). I looked for a stuck button but did not find one. I just pushed all the buttons a few times in case one was stuck (as suggested on other sites) and that did it!
Hope helps.
6/11/2011 4:34:45 PM • Haier ESA3109... • Answered on Jun 11, 2011
DOESN'T SEEM TO BE COOLING
start by checking the air filter and clean if dirty, also I would recommnd spraying a coil cleaner on the evaporator coil and clean it. If the unit appears clean then most likely the unit has a leak and will need to be recharged with refrigerant.
6/7/2011 1:48:03 PM • Haier ESA3109... • Answered on Jun 07, 2011
Haier CWH24A. It isn't heating now that it's back on Heat mode
Question edited for clarity and add maker. Try a reset. Disconnect mains power for at least 2 hours. Reconnect and wait 5 minutes before turning on. This resets the mainboard and initiates a self test procedure. https://www.google.com/search?q=+Haier+CWH24A+not+heating+up ..
11/5/2023 9:53:52 PM • Haier Heating &... • Answered on Nov 05, 2023
Please my Haier Thermocool Ac automatically sets to 26c when I set it to 16 or any other number. It decreases slowly to 24 and stays there. Please what can be the cause of this? I need answers.
You will be able to get the answers from Haier support in your country. We are Fixya, not them. It sounds like a control board fault. You can try a reset. Turn it off at the breaker for 2 hours. Switch it back on and wait 5 minutes before turning the unit back on with the remote. https://www.google.com/search?q=Haier+Thermocool+AC ..
9/18/2023 6:30:27 PM • Haier Heating &... • Answered on Sep 18, 2023
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
11/8/2022 6:04:59 AM • Haier Heating &... • Answered on Nov 08, 2022
2answers
Remote for haier split- ac hsu-18dx"?
Window ac
9/20/2022 5:13:07 AM • Haier Heating &... • Answered on Sep 20, 2022
Haier ESA3109 WallWindow Air Conditioner Logo
Popular Tags
27 questions posted
Top Haier Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
top bottom coils ice up no
  • Heating & Cooling
