20 Most Recent
Westinghouse 78092 Verandah Breeze Ceiling Fan Questions & Answers
My outdoor ceiling fan doesn't
The amount of air a fan can blow is determined by how much air it has to pull. The closer the fan is to the ceiling the less air is available. You may need to get an extension to put between the ceiling and the fan. It's a hollow rod. You can get them a places like Lowes.
Another possible problem with outdoor fans is that the high humidity can cause the blades to warp and not have the proper shape and angle to move the air. Metal blades would be the best for outdoors.
Make sure the fan is turning the correct direction to blow down.
Need help refitting the tension spring and belt to a Westinghouse dryer
You need to feed the belt around the tensioner first but release the tension from the tensioner. Place something under it to keep it from expanding open and the feed the belt onto the drum. If you get it started you can turn the drum and it will feed itself onto the drum. Once that is done, align the belt visually for straightness and gently release the tension. Voila
