20 Most Recent Waterway 519-4020 Questions & Answers
I bought a new waterway 1 hp self prime pool pump yesterday. It runs for 5 min. and gets very hot and blows the gfi. Is it a bad new pump or a bad gfi? /very frustrating
If the pump is getting hot check the voltage to make sure it is within 10% if it is it is a bad pump if it is not bad gfi
3/31/2019 2:29:14 AM • Waterway Pool &... • Answered on Mar 31, 2019
Uninstalling a waterway pool pump ph2200-6
switch of the power and isolate the power cord. To uninstall unthread the two inch discharge port union,then the 1.5 intake port union.
1/14/2019 6:28:56 PM • Waterway Pool &... • Answered on Jan 14, 2019
I have a waterway 115v, 2 hp 2 speed pump that starts in the low speed setting but hums in the high speed setting. replaced the starting capacitor, checked the starting switch and governor, both ok
perhaps you should take it to motor shop ( google motor rewind and repair in your area).. Electrical motors that run in water should be repaired by insured shop.
4/12/2018 3:35:55 AM • Waterway Pool &... • Answered on Apr 12, 2018
Waterway pump and sand filer: when pump s running I it has water draining it the waste drain
reposition the 3 way tap for the sand filter
3/9/2018 5:27:14 AM • Waterway Pool &... • Answered on Mar 09, 2018
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections. Common is always the white wire High speed is normally red Low speed is Black Green wire is always green
2/1/2018 6:02:20 AM • Waterway Pool &... • Answered on Feb 01, 2018
1.5 hp 2 speed waterway pump only hums. Finished vacuuming and went to turn pump back on it hims and then trips breaker. Shaft moves freely, unable to start by turning with screwdriver. Capacitor?
Most likely the run capacitor yes. Some motors have 2 capacitors, some one, some a combined start/run capacitor. Replace it with one the same or greater voltage, and the same capacitance.
7/24/2017 2:55:45 PM • Waterway Pool &... • Answered on Jul 24, 2017
Waterway high flo pumps works fine in low speed not at all on high
need new 2 speed relay
9/18/2016 9:13:56 PM • Waterway Pool &... • Answered on Sep 18, 2016
0answers
Pump
Be the first to answer 5/25/2016 12:41:12 AM • Waterway Pool &... • Posted on May 25, 2016Be the first to answer
Waterway 519-4020 Logo
1 questions posted
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Waterway Pool & Spa
  • Waterway Pool & Spa
Most Popular Question
waterway pump sand filer when pump s
  • Pool & Spa
