20 Most Recent
OKI MICROLINE 5521 Matrix Printer Questions & Answers
How to change the pin head
I assume your asking how to change the "Print head" power off the machine, remove the ribbion and plastic mask (lifts up) you will see 2 gold phillips head screws. unscrew them both and lift up the print head. push in new print head and reverse the directions you removed.
Hp deskjet 1180c
try this:
- place good cartridges
- turn off printer
- press and hold power button until printhead is moving
- release power button
- your printer should be working again
OKI MICROLINE 5521 PRINTER PROBLEM
Hi. Your printer may be in a need of basic service to clear up the jamming problem. The printer has comfiguration settings. If the configuration settings are correct, then there is no need to worry - just a basic service to the rear pressure rollers and front pressure rollers. Sometimes when the printer prints for a long time over months, then there is quite a lot of build-in paper pieces inside the platten assembly. Either if it jams, often there is sometimes piece of paper stuck below the platten assembly or in between the pressure rollers...
