20 Most Recent Verbatim Cd-Rw,650Mb (ver91664) 4x Storage Media Questions & Answers
How to write to a Verbatim CD-R
You need a DVD / CD Writer.
7/29/2010 5:58:38 PM • Verbatim... • Answered on Jul 29, 2010
How can I remove the bitlocker from my stick as i do not have the password any longer
The best way to remove bitlocker on win 7 is to follow the following simple steps.1- click start 2- click control panel 3- While on control panel, find Bitlocker Drive Encryption icon and click on it 4- here you will see all the partitions on your hard drive and their encryption status, either encrypted or not. 5- on the one that is encrypted, you will find an option to turn off bitlocker. click on it and wait for the machine to decrypt. Hope this helps
9/15/2014 12:15:43 AM • Verbatim... • Answered on Sep 15, 2014
How to run verbatim store & Go pendrive as privleged user?
Go the the Verbatim web site and search for your product at the bottom of the screen is the support button click it then go to downloads and download the V-safe software again then drag the downloaded file back onto your flash drive then just click on it and just put in your password again....it should access the private zone then.
9/15/2014 12:10:52 AM • Verbatim... • Answered on Sep 15, 2014
Why does my memory card says no memory card when its in my camera?
Try re-formatting the card.
8/17/2014 4:15:07 AM • Verbatim... • Answered on Aug 17, 2014
Code 43
http://www.windowsanswers.net/slimware2/fix-code43?tid=code43goog&p2=^SW1^xdm015&gclid=CPWukdCSjb8CFTJp7AodlU0Ang
6/22/2014 9:15:55 AM • Verbatim... • Answered on Jun 22, 2014
USB drive, safe folder - Vsafe 100
If you are talking about the Sim Card on a phone. Then you cannot change the password. In order to do you. You have to talk to your Phone Maker..... If this doesnt answer your question, contact us at [email protected]
1/29/2014 5:21:45 PM • Verbatim... • Answered on Jan 29, 2014
Valuable Information
Reformat it
1/20/2014 3:48:47 AM • Verbatim... • Answered on Jan 20, 2014
Volume label
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
12/24/2013 4:13:36 PM • Verbatim... • Answered on Dec 24, 2013
Avast antivirus free download
Where is the virus being detected?
11/7/2013 8:58:01 AM • Verbatim... • Answered on Nov 07, 2013
Verbatim portable hard drive has stopped being
try pluging in HDD to another computer to see if problem is with HDD or with your laptop, if HDD works OK with another computer that laptop has an issue
9/25/2013 4:37:24 AM • Verbatim... • Answered on Sep 25, 2013
How to dowmload information to my flash drive
copy and paste the files you want to the other device. the START menu will contain My Computer and you will be able to see your USB Flash drive..Open your flash drive, then locate the files you want to 'download' or usually its called 'Copy' by right click the picture and selecting copy, then go back to your USB Flash drive window, right click and select paste...Hope that helps you =)
2/22/2013 4:42:43 AM • Verbatim... • Answered on Feb 22, 2013
How to download on verbatim flashdrive
Hi, if you want to download to the flashdrive, or external memory device you are able to "Browse" the location you would like to usually before downloading, like something from the internet. If you are trying to save pictures from your computer onto your USB flashdrive you can right click your picture, select copy then goto your start menu and select & open your USB drive, then right click and paste into the window or a folder that you have created. To create a folder on your USB, just right click into a blank space in your USB window when opened, and select NEW, then Folder =) Hope that helped
2/22/2013 4:29:58 AM • Verbatim... • Answered on Feb 22, 2013
My varbatim card 32 gb is not decated
On a Windows computer
  • Plug card in
  • Right click Computer > Manage > Disk Management
  • If the card is detected here right click it and delete any volumes on it.
  • Right click it again and select New Simple Volume. Defaults are fine.
If Windows doesn't see it at all you may need a linux live cd to access and format it with Gparted.If it can't be detected in Linux the card is probably dead.
2/5/2013 5:51:27 AM • Verbatim... • Answered on Feb 05, 2013
My thumbdrive has water damage, what do I do?
it might have been water damaged beyond repair ?orclick start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts hope it helps
8/27/2012 1:18:05 AM • Verbatim... • Answered on Aug 27, 2012
Verbatim 47534 format
click start click on my computer you should see your usb drive right click then select format another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps
8/4/2012 8:00:08 AM • Verbatim... • Answered on Aug 04, 2012
Verbatim USB drivers
not sure about specific verbatin usb drivers if you are having problems with your usb driversclick start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions they will automatically search for and find the correct driver also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name sound drivers
http://www.innovative-sol.com/drivermax/ free program, paid update available
hope it helps
5/5/2012 11:26:56 PM • Verbatim... • Answered on May 05, 2012
How to remove the write protection on a 8 gb sdhc from verbatim
click start click to open on my computer you should see your micro usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your micro usb drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. hope this helps you
4/9/2012 3:10:47 AM • Verbatim... • Answered on Apr 09, 2012
2answers
5.84 GB will not fit on the 8GB Store N Go
Easy Fix.. You need to reformat your USB File System to NTFS rather than FAT32 (Default). FAT32 limits the size of all downloads to 4 GB. NTFS has no upper limit so you could download an 8GB file, if you wanted..... FAT32 is the default on the unit you have. Easy fix.... right click on your drive, click 'format', 'file system' change to NTFS and click 'start'. That's it ! ! ! !
11/19/2009 3:46:21 AM • Verbatim... • Answered on Nov 19, 2009
I bought Verbatim
You will need a printer with a cd tray that holds on to the disk while its printing,
My print tray moves backwards and forwards past the printer head as it applies micro dots of ink to build a finished image,
I have a Cannon i8 65,prints straight onto the surface of the disk,awesome photo quality prints on the disk,
Versatile with print various formats and media types too,Glossy,Matte,DVD,CDs,etc
Great prints and a sturdy machine too...
Hope this helps,MISTERDJ
8/2/2009 1:37:49 AM • Verbatim... • Answered on Aug 02, 2009
Verbatim Cd-Rw,650Mb (ver91664) 4x Storage Media Logo
1 questions posted
Top Verbatim Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Verbatim Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Verbatim Electronics - Others
Most Popular Question
write verbatim cd r
  • Electronics - Others
