20 Most Recent
Yamaha HTR-5460 5.1 Channels Receiver Questions & Answers
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
I have a Yamaha RX-v1800 amplifier. Need help connecting a Bluetooth music receiver
To connect the Bluetooth music receiver to your Yamaha RX-V1800 amplifier, you will need to use one of the available input options on the amplifier. The Yamaha RX-V1800 should have various audio input ports, and the specific connection method will depend on the output options provided by your Bluetooth music receiver. Here are the general steps to connect the receiver:
- Identify the audio output options of the Bluetooth music receiver: Check the output ports of the Bluetooth receiver and determine what type of connection it supports. Common output options include:
- 3.5mm headphone jack (analog)
- RCA (analog)
- Optical (digital)
- Choose the corresponding input on the Yamaha RX-V1800: Depending on the output options of the Bluetooth music receiver, you need to select the appropriate input on the amplifier. The Yamaha RX-V1800 should have various input options, such as:
- AUX (usually a 3.5mm stereo input)
- CD (analog RCA input)
- DVD/BD (analog RCA input)
- OPTICAL (digital optical input)
- Connect the Bluetooth music receiver to the amplifier: Use the appropriate cable or adapter to connect the output of the Bluetooth music receiver to the selected input on the Yamaha RX-V1800. Here's how to do it based on the different output and input options:a. If the Bluetooth receiver has a 3.5mm headphone jack (analog output) and the Yamaha amplifier has an AUX input (3.5mm stereo input), use a 3.5mm to 3.5mm audio cable to connect them.
b. If the Bluetooth receiver has RCA outputs (analog) and the Yamaha amplifier has corresponding RCA inputs (CD or DVD/BD), use an RCA cable (red and white connectors) to connect them.
c. If the Bluetooth receiver has a digital optical output and the Yamaha amplifier has an optical input, use a digital optical cable to connect them.
- Set the input source on the amplifier: Once the Bluetooth receiver is physically connected to the amplifier, you'll need to select the corresponding input source on the Yamaha RX-V1800. Use the amplifier's remote control or front panel to select the input source you connected the Bluetooth receiver to (e.g., AUX, CD, DVD, OPTICAL, etc.).
- Pair and play: Turn on the Bluetooth function on your iPhone, put the Bluetooth receiver into pairing mode, and pair it with your iPhone. Once paired, you should be able to play your music from the iPhone, and the audio will be transmitted to the Yamaha RX-V1800 amplifier for playback.
Please note that the specific labels of the inputs on your Yamaha RX-V1800 might differ slightly from what I've mentioned, but the general concept of connecting the Bluetooth music receiver remains the same. Always refer to your amplifier's user manual for the exact location and naming of the input ports.
