20 Most Recent
Electric Mobility Geo Wheelchair Drive Power Chair Electric Red Indoor Questions & Answers
I have a power chair
Does your chair have the nine pin connector from the joystick to the rear of the chair? If it does have them replace the main nine pin harness in the base. this harness connects the batteries and the motors and supplies the power to your motors through the joystick. I have found these give the problem you are having yet doesn't give any errors that you might have a bad motor etc Fairly cheap fix harness should cost about $20.00 Hope this helps
5/29/2011 10:41:21 AM •
Electric...
Answered
on May 29, 2011
Hello i have a kymco xl mobility scooter which has
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault There is a bad connection to the motor and the controllerIf 's it a Rhino controller normally a blue colour , The battery is completely empty. The scooter does not drive.• Recharge the battery immediately.If the scooter is left off for a few minutes, the battery may recover enoughto allow driving again for a short time. However, driving on an emptybattery may cause damage to the battery.Regardswww.gewizrepairs.co.uk
3/24/2022 8:52:42 AM •
Electric...
Answered
on Mar 24, 2022
Wigwag Throttle Control Pot FREERIDER loose
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
3/25/2019 7:44:39 AM •
Electric...
Answered
on Mar 25, 2019
