20 Most Recent
Sony BDVT11 Theater System Questions & Answers
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
The display does not work on my Sony CDP-CE375 CD Player.
troubleshoot the issue:
Reset the CD Changer:
Turn off the CD player.
Press the CLEAR button.
Simultaneously, press and hold down the POWER button on the CD player for 60 seconds.
If this doesn't resolve the issue, proceed to the next step.
Check for Error Messages:
If you encounter difficulty playing a disc and receive any of the following error messages, there may be an incorrect setting or a problem with the disc:
NO DISC
DISC ERROR
CD ERROR
TOC ERROR
Refer to the instructions supplied with your CD player to verify model-specific information and troubleshoot the issue.
Internal Component Repair:
If the display issue persists, it might be related to an internal component that requires repair.
My Sony model # MHC-V11 MAKES NO SOUND everything seems to operate but i cant get no sound from it
Troubleshoot this issue. Here are some steps you can follow:
Check Speaker Connections:
Ensure that the rear surround speakers are properly connected to the Audio/Video (A/V) receiver.
If applicable to your model, verify that the A/B speaker selector is set correctly. If the speakers are connected to the A speaker connection, the selector must be set to the A position.
Test Tone Operation:
Perform a test tone operation to check if the speakers are functioning correctly.
Increase the rear speaker volume or adjust the surround speaker settings to the maximum level.
Speaker Size Settings:
Try selecting a different size (small or large) for the rear surround speakers in the menu.
Surround Sound Mode:
Verify that the A/V receiver is set to a surround sound mode.
For Dolby ProLogic surround sound, ensure that the center-channel mode is set to NORMAL or WIDE.
If your source is a DVD or Blu-ray Disc player, check that surround sound is enabled in the player's menu.
The audio being received must be multi-channel.
Different Surround Sound Mode:
Try setting the A/V receiver to a different surround sound mode.
Source Content:
Verify that the source you are playing is encoded in surround sound.
Note that during periods of mainly dialog, most of the sound may come from the center speaker only, with audio coming out of the rear speakers when there is background or ambient noise.
Factory Reset:
Reset the unit back to factory default settings (consult your operating instructions for model-specific steps).
If applicable, follow the steps for calibrating the appropriate settings automatically after connecting the calibration microphone device.
Speaker Wires and Replacement:
Check and replace the speaker wires if necessary.
Consider connecting a different pair of speakers to see if the issue persists.
If you've tried these steps and the problem remains unresolved, I recommend seeking professional service.
My Sony DHC-FLX7D and DHC-FLX5D is not working due to humidity. Is it possible to repair it ?
steps to troubleshoot and potentially repair them:
Troubleshooting Low Sound or No Audio from Rear Surround Sound Speakers:
If you're facing audio problems, especially with the rear surround sound speakers, consider checking the following:
Ensure that all speaker connections are secure and properly plugged in.
Verify that the speaker wires are not damaged or frayed.
Check the speaker settings in the system menu to ensure correct configuration.
Inspect the speaker impedance and compatibility with the system.
If you're using wireless speakers, check their power supply and connectivity.
Refer to the operating instructions manual for specific troubleshooting steps.
Flexible Circuit Board Repairing:
If the issue is related to internal components, you might need professional repair. However, if you're comfortable with electronics, consider these precautions:
Keep the soldering iron temperature around 270°C during repairs.
Avoid touching the soldering iron on the same conductor of the circuit board more than three times.
Be gentle when soldering or unsoldering to prevent damage to the conductor.
Important Notice:
To prevent fire or shock hazard, avoid exposing the unit to rain or moisture.
Do not open the cabinet; refer servicing to qualified personnel.
Avoid installing the appliance in confined spaces like bookcases or built-in cabinets.
