20 Most Recent
Artec e+48u Flatbed Scanner Questions & Answers
Artec e+48u scanner problem
go to control panel, under device manager uninstall imaging device (scanner) and click scan for hardware changes, if found new hardware occurred click next and choose no, not this time tab / choose install from the list specific location option tab / choose don't search i will choose the driver to install / click show compatible hardware tabs and select scanner type appeared.
I want to enlarge my scan to printer
I have two suggestions that may assist you.First, update your drivers since Artec has published some significant fixes. You can down load the fixes by
CLICKING HERE.Next, let Microsoft check and fix any problems with the operating system in three easy clicks.
CLICK HERE
My software is lost and
I have windows office but no disk for the artec 48u flatbed scanner is there a free download driver i could use to get it to work?
I have no installation disc. can I stll install
Hello thanks for using Fixya
With non availability of installer disk just download its driver, You will surely make able to install your scanner with computer.You can easily & free download the driver of Artec e+48u Flatbed Scanner
After clicking it will take some time and then downloading will automatically start
After Download it install it on your PC & enjoy
Further assistance i am here to
help
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using Fixya
Need drivers for windows 7
There are no drivers under W7 for your unit .
If you have the XP install disc , you could install a virtual version of XP on your HDD .
You could also partition your Hdd to install W XP on the new one .
Otherwise , there is no other solution than buying a new device .
Regards .
I need a driver for
There are no more drivers for this scanner under Windows Seven .
If you have Win XP install disc , you can install a virtual version of XP on your existing HDD with WMware Player , for instance . It's free and works fine and is the only way to get your device running if you don' t want to by a new one .
How doI run windows 7 in XP compatabiliyt mode to
Hello sramnesia
Insert your driver cd and open the cd with my computer.
You should be able to see a setup.exe file. Right click on the file and select properties. Then , under the compatibility tab , select the check box (run this program in compatibility mode) and select windows XP sp2.
After doing this press okay and run the setup file. It should be able to install. If it does not , let me know and we can look into some other options.
Kind Regards
StephanSA
